View Full Version : Header clearance
Btyner
05-08-2013, 05:18 PM
I have 68 camaro with 383 with richmond six speed. I recently purchased true turn system but it will not clear my headman headers which are 1/3/4. I called Ride tech and they stated that they are pretty sure that the Dynatech headers will work. I need to run 1/3/4 headers on my motor just wondering if anyone has any information or actual application for my car thanks for anybodys help.
Spitfire100
05-09-2013, 04:29 AM
I have a 69 small block, Tru Turn, power steering, Dynatechs with no problem. The pitman arm on manual steering is shorter which can cause some problems. I currently still have a Muncie 4 speed, but am in the process of changing to a TKO 600.
Btyner
05-09-2013, 05:49 AM
Thanks, that will help a bunch.
blu72nova
05-10-2013, 07:47 AM
Spitfire what heads do you have? Are they angle or straight plug?
killer69
05-10-2013, 08:11 AM
We have a 69 Camaro in the shop with Dynatech LS headers and they hang down SO LOW it is Ridiculous that a header company would make a header that is 3" below the floor??? they hang 3" below the bottom of the sub frame.
Spitfire100
05-11-2013, 12:24 PM
Straight
Btyner
05-12-2013, 06:10 PM
What part number did you use? what size dyna techs are you using thanks again for your help.
Spitfire100
05-13-2013, 02:43 PM
They are the 1 5/8 to 1 3/4 stepped not sure of part no. I'm out of town, I'll see if I can find it and post.
