    Results 1 to 5 of 5
      Feb 2012
      Where is '68 Conv top switch??
      I have a '68 Firebird coupe.....with nothing in the dash when I got it
      I am going to wire in cruise with my LS1 and am planning on using the single button early GM cruise stalk......I was thinking of installing a convertable top switch and wiring/using it to accomplish the tap up/tap down function. I was hoping it mounted in an inconspicous location like the under lip of the dash shell-----pics would be cool too
      Thanx
      Feb 2012
      ??? anyone??
      Feb 2012
      ^^^^bump
      Feb 2002
      Santee, CA
      Yep, the convertible switch mounts underneath the gauge cluster bezel on the left hand side (see picture below). The switch isn't cheap though. You're going to need the switch and the housing (around $60-$70). If your bezel doesn't have this hole, it might be better to just mount a more modern rocker switch from Radio Shack (much cheaper to!)
      Feb 2012
      Yippeee Skippeee Just when I was feeling vulnerable and no one noticed my question...POP there it is....thanx
