View Full Version : Steering Question need help ASAP
eversmann79
04-18-2013, 09:47 AM
i was out with my car 69 camaro manual steering
front suspension is rebuilt completely, and as i was parking i heard this popping noise in my car while i was cranking the wheel.
and now the steering wheel just spins, and tires dont move?
is it the coupler or would it be the box and all?
dontlifttoshift
04-18-2013, 09:54 AM
open the hood. Is the rag joint still attached? Did the pitman arm fall off? That's really all it could be.
eversmann79
04-18-2013, 11:43 AM
rag joint is still attached if i spin the steering wheel, the upper shaft spins the lower one going to the box does not
dontlifttoshift
04-18-2013, 02:34 PM
So then the rag joint is not still attached.
eversmann79
04-19-2013, 03:00 AM
Not sounding like it. I'll try to crank all the bolts down and see if that helps
04-19-2013, 05:19 AM
Remove the coupler & inspect.
