Results 1 to 2 of 2
03-28-2013 #1
- Join Date
- Aug 2009
- Posts
- 277
Trunk Mounted Battery and Stereo Amplifiers
I am looking to re-locate the battery to the trunk using the MAD components using the solenoid to turn the main cranking power off and it appears that the charge wire for the battery is only a 10 gauge wire. Everything I know about power amps has you running a large battery cable from the amps to the battery. So, do you still run the amp cables up to the junction point for the alternator connection, or do you re-size the charge wire to handle the higher current and run the amp wires directly to the battery?
