View Full Version : Hub Centric Rings?
GeoffP
02-24-2013, 11:58 AM
Does anybody know the correct hub centric ring to use when mounting a BMW wheel on a 68 Camaro? I'd like to get these ordered so they'll be here when my wheels come in.
Thanks!!
Apogee
02-25-2013, 04:34 PM
That would depend on what you're mounting them to...factory drum hubs? OE discs? Something aftermarket? The most common BMW center bore size is 72.5mm if I recall correctly, where the standard GM wheel pilot dimension is 70.5mm for the older application, 70.3mm for the newer ones. I take it you're not accounting for the 5x120mm wheel pattern mismatch?
Tobin
KORE3
GeoffP
02-25-2013, 05:58 PM
Yes sir - I bought a set of PCD correction nuts but want to make sure the wheel is properly centered. The sizes you listed are the same as I found elsewhere. I was looking at the front hubs on my car tonight - they're the billet Wilwood hubs so they are not a consistent diameter. I need to buy a caliper to I can measure it both front and rear hubs so I can get it right.
Apogee
02-25-2013, 06:11 PM
The Wilwood hubs have a tapered snout and are not intended for hub-centric wheel fitments.
analyte
02-25-2013, 06:53 PM
What wheels did you buy?
Kerry
GeoffP
02-25-2013, 07:37 PM
I bought a set of Beyern "5"'s - hope I didn't make a mistake! Guess I'll know tomorrow.
jpgolf14
02-27-2013, 03:43 PM
It will be tricky with the Wilwood hubs. You could make a custom tapered hubcentric ring.
But frankly it would be best to redrill the wheels or get a set of hubs that has the correct bolt pattern.
GeoffP
02-27-2013, 06:54 PM
I fit one of them last night and spun the wheel around. I didn't see any visible wobble. I'll feel better when I can get the PCD correct nuts to see if I can get the wheels properly centered on the front hubs. If not, then a call to Wilwood is in order to see if they can do a custom drilled 5x120mm hub.
kaine876
08-20-2013, 04:08 PM
@Geoffp were did you buy the corrective lug nuts from been searching for months .yours or any other member response would be greatly appreciated thank
GeoffP
08-21-2013, 04:24 AM
@Geoffp were did you buy the corrective lug nuts from been searching for months .yours or any other member response would be greatly appreciated thankI bought them through eBay from an overseas vendor. They were expensive. What's bad is that I didn't end up using them at Wilwood's request. Their technician told me they are not necessary as long as the bolts are kept torqued. I have checked the torque several times and found no loose lugs (so far).
kaine876
08-21-2013, 07:47 AM
Thank u i will finally get to put my rims on ,did you use stock lugnuts or aftermarket ..one more question .was there any different material used to make ur lug studs from a factory stud on 1994 sonoma that u know off
GeoffP
08-21-2013, 02:42 PM
I used aftermarket lug nuts. My car has 1/2" studs front and rear. I am fairly certain all 4 wheels have ARP studs. I know the fronts do because they are screw-in ARP studs provided by Wilwood with their hubs. The rear came from Moser already pressed in with the axles I bought for my car.
kaine876
08-21-2013, 05:09 PM
thank u for the info thought u had them on stock studs....and nice camaro hopefully i can get my hand on a ls1 for my s15 1 day
GeoffP
08-21-2013, 05:18 PM
You're welcome. I am always glad to help if I'm able. Thanks for the compliment! I enjoy it as often as possible. Keep your eyes open...there are deals out there to be had if you're patient.
kaine876
08-22-2013, 03:38 AM
I would too .....alright i will keep looking and ill be back with more question thanks again
kaine876
08-22-2013, 04:22 AM
Do you still have the pcd corec lugnuts,if u do are u willing to sell
Skip Fix
08-22-2013, 10:47 AM
So how do lugnuts change the variation in the diamter of the stud bolt pattern?
GeoffP
08-22-2013, 03:38 PM
PCD corrective lug nuts have a captured washer that is the cone end of the lug nut - this washer end nut allows for minor bolt circle variations.
Skip Fix
08-23-2013, 08:18 AM
Thanks for the explanation.
