View Full Version : C5/C6 upper control arm dimensions
Ppd1979
01-25-2013, 03:44 PM
Looking for the dimensions of a front upper control arm for a C5/C6 corvette.
*ball joint center to bushing centerline.
*center of bushing to center of bushing
marolf101x
01-26-2013, 11:23 AM
in the upper right hand corner you will find the search box. Please use it as this has been discussed a million times.
Ppd1979
01-26-2013, 09:33 PM
Prior to posting, I did use the search function, I did find a posting where they stated the length looking straight down on the car, but I'm not sure at what ride height that was at. That's why I'm asking the questions.
sixfeetunderoffroad
01-27-2013, 05:36 AM
On ride height. Im sure it was stock. If its slammed, the a arm would be slightly longer and ball joint angle would change. Prob does not help. Just thought i would throw it out there.
Ppd1979
01-27-2013, 07:55 AM
Found this info previously, not sure if this was at ride height?
Front UCA/LCA Length (BJ Pivot to bushing centerline):
UCA: 8.55"
LCA: 15.96"
UBJ to LBJ: 12.614"
those measurements are from a top view
