View Full Version : Male bulkhead connection P/N
77tony
01-19-2013, 06:09 PM
Looking for a P/N or source for the male end that plugs into the bulkhead connector attached. Plan is to tie in the female GM connector through a male end and into the existing 14 pin connector on a 1980 Porsche 928 (Just Peachy) TIA. 77tony
esenior
01-21-2013, 02:45 PM
Try searching through the Mouser online catalog and enter in the specifics of the connector. I did some quick poking around and found what looks like a match (but I don't know the specifics on your connector).
http://www.mouser.com/Search/Refine.aspx?Keyword=15326854
http://www.mouser.com/ds/2/105/15326978_CUS01_S01.tif-13732.pdf
http://delphi.com/connectors/feature/search?search=15326854
77tony
01-21-2013, 05:33 PM
Thanks, That's what I am looking for but maybe need to source at the junkyards for the male connector & approx 2' of wiring hanging out to tie in to existing system (Porsche) wiring. T
esenior
01-21-2013, 10:05 PM
If you search the Delphi web site (http://delphi.com/connectors) for the connector, you can click on the tab for related products in order to get the part numbers for the insulators and pins. This still requires that you crimp/solder up your own harness though. I've also bought a few harnesses from the junk yard (for my Le Sabre mirrors), always a good time poking seeing what you can find!
