    Results 1 to 8 of 8
      Jun 2008
      San Antonio
      Took apart my steering column
      Dont remember where this ring went. Its a steel ring/spacer. Can anybody help me out. Thanks in advance.
      1971 El Camino PT, SC&C, TBJ, UMI bars, UMI LCAs, Hotchkis, C5 brakes, VWW V48s
      "Project Inferno"
      Jun 2008
      San Antonio
      This is on my 71 Camino, no tilt.
      "Project Inferno"
      Lawrenceburg, TN
      hopefully some can help, did you look in or own the El Camino/Chevelle assembly Manual? Its also is in the Chassis Manual for that car, the steering column/ and posi unit are the only 2 things I sent out for rebuild
      Oct 2009
      i have that on my 69 non tilt column. i believe if i remember correctly it is the bearing thrust washer
      no. 11
      http://www.camaros.net/forums/showthread.php?t=95769
      1969 frost green camaro
      LS3
      Speedtech pro touring front subframe
      ridetech rear 4-link
      moser 12 bolt eaton tru trac 3.73
      Jun 2008
      San Antonio
      I think it goes under this spring. I know it needs to bring the steering wheel away from column. Because, the hub on the grant wheel is rubbing the column when I turn..
      "Project Inferno"
      Jun 2008
      San Antonio
      "Project Inferno"
      Jul 2008
      milton, florida
      i can help you out, i have quite a few non tilts and parts, give me a ring in the evening at 850-564-0072, Jim
      Jan 2012
      Dallas, Texas
      Did you figur out where it goes?
