View Full Version : Single Adjustable Shocks: Rebound only vs Compression + Rebound
ericwy
01-07-2013, 05:43 PM
Regarding single adjustable shocks: (given: the single adjustable is less versatile than a double adjustable)
On the surface it would seem that the single adjustable with simultaneous rebound + compression
adjustment would provide more performance advantage than the rebound only single adjustable when
set to similar rebound.
Thoughts?
Gitter Dun
01-07-2013, 06:05 PM
Problem I've run into with single adjustable compression/rebound adjustment is the shock bouncing under high load. Could be the brand of shock I'm using......dont know for sure but I recommend double adjustables.
