    Results 1 to 10 of 10
      North of Toronto
      69 Camaro Vintage air through the heater hole
      Can anyone post pics and tips on what they did to run the vintage air kit through the heater hole. I have already purchased the DSE blank off plate as well.
      I would like to hide all the hoses in the inner fender.
      Documented 302 Z-28 car updated restoration underway.
      Dec 2010
      Calgary, Canada
      I second this question
      Jul 2011
      NC
      Think i have a few on my build thread
      Josh
      "Schism"
      69 camaro
      Sep 2009
      Li,Ny
      I am doing this now if you order a fender well hose kit they give you all the stuff. i welded the blower motor hole closed and drilled 1 1/4 inch holes and used there grommets from the kit instead of the plastic filler they give u .Ill try and post some pics later
      Sep 2009
      Li,Ny
      Heres some pics
      Jul 2012
      evansville indiana
      Quote Originally Posted by kush69 View Post
      this is exactly what i did. i called vintage air and ordered the exact components they used on the 48hr camaro build ez clip hose fittings as well...
      Aug 2009
      Napa, Ca.
      Here you go.
      Jeff
      69 Camaro build, body & paint by West Coast Auto Craft
      Build thread http://www.lateral-g.net/forums/show...ght=brownstone
      Lateral-g Feature http://www.lateral-g.net/forums/showthread.php4?t=44186
      Thanks to Matt's Classic Bowties and Pro-Touring.com
      Aug 2006
      Heres some pics
      Man that is exactly what I am looking for as well. Could you please post the part number for the kit? Did the kit come with extra length hoses to run behind the fender well?
      72 Camaro RS:SOLD
      68 Camaro:
      LS6 Engine,Tremec TKO 600,5 Speed
      Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors
      North of Toronto
      I have been thinking about this Bulkhead from Restomod Air. I would love to see it actually on a car.
      I wont be going the plastic route for sure.
      Dec 2010
      Fredericksburg, VA.
      I like the firewall routing but I would upgrade to silicone heater hose in place of the standard rubber hose. Once the front clip is installed those hoses would be a bitch to replace.
      http://www.hps-siliconehoses.com/
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
