    Results 1 to 7 of 7
      Jul 2009
      arkansas
      Which seat belts, Morris or Corbeau?
      Has anyone used the Corbeau 3 point retractable seatbelts. These are $79 each which is considerably cheaper than the Morris 3 point set. I've seen several posts about the Morris belts, but nothing about the Corbeau belts.
      Anniston, Al
      I've been looking around at 3 point seat belts too. Looks like the main advantage with the morris kits are they have done the engineering to make them a bolt in 3 point seat belt, so you get all the brackets you need for a pretty simple install. With the Corbeau and others I have looked at they are universal so you will probably have to do some fabricating and make sure you have strong mounting points. Also I'm not sure the corbeau belts would work in the back seat which may not matter if you're only concerned with the front. I'm still not sure which way I will go it is tempting to save that much money and just do some fab work but it would also be nice to just not worry about it and bolt the morris belts in.
      1967 Firebird (current project)
      1967 Firebird (unfinished project SOLD)
      Jul 2009
      arkansas
      Thank you for the info.
      Wall,
      Thank You for the Compliment.
      As you stated our seat belts are engineered for year and car specific applications. No assembly just bolt in. Also we use all of the factory mounting points as the manufacture tested the cars with them mounted in those places.
      Our seat belts are also tested weekly or if any lot number of any part is changed. Sewn, tested and assembled in the USA. Look in the General Tech & Safety Equipment section and it is quite obvious that the extra cost is money well spent avoiding personal injury. Our seat belts eliminate the what if question about mounting and seat belt restraint . Billy
      Jun 2010
      Georgia
      we selected Morris for our 3pt belts, and will use Schroth Rallye harnesses for track days only.
      Sep 2013
      Quote Originally Posted by morrisclassic View Post
      Wall,
      do you have rear 3 point harnesses for a '66 chevelle?
      Scott
      '66 Chevelle
      We have the rear 3 points for 66-73 Chevelles, Camaros, Firebirds.
      All of our seat belts bolt into all the factory mounting points
      All of our 3 point seat belts are year and car specific, preassembled
      with grade 8 bolts.
      Billy
