View Full Version : 72 cutlass rear disc brake question
oldsmobeast72
12-01-2012, 12:12 PM
I have a 72 cutlass with a bop 8.5 10 bolt. I'm wanting to do a junkyard rear disc brake swap. I've read about the ls1 camaro brakes on a chevelle but I'm pretty sure my axle flange is different. Anyone have any suggestions?
csouth
12-01-2012, 02:55 PM
That '72 should have the Corporate 10 bolt, the backing plates will bolt right up.
oldsmobeast72
12-01-2012, 08:40 PM
Ok, thanks a lot!
raustinss
12-02-2012, 11:52 AM
I've got freshly powder coated 77-79 Cadillac Seville rear disc backing plates...dirty cheap they're on a twelve bolt now but will bolt on a ten bolt....to use them you need the same caddy calibers and disc's if you want 5on 5" bolt pattern if you want typical gm car 4.5 " I believe..use 79-81 firebird ws6 rear rotors..the whole set up is less then 200$ ..make a offer and the brackets are yours.
Ryan [email protected]
