View Full Version : AUTOPAGE RS-1000 1Mile - HIGH END ALARM
86regalss
11-19-2012, 02:06 PM
AUTOPAGE RS-1000 1Mile - HIGH END ALARM (https://www.pro-touring.com/classifieds.php?mshow=listing&id=autopage-rs-1000-1mile-high-end-alarm-1465)
6 Channel Alarm and Remote Car Starter with 5 on-board MICRO relays for parking lights, starter, accessories, ignition 1&2 and one additional relay / socket for starter disable.
C3 Compatible with On-board Serial Port for AP Data Link Data Bus Integration
Two-way paging receiver and transmitting remote with 3-color LCD screen using FM frequency bands for transmitting and receiving at 900 megahertz. Unit will transmit and receive up to 1 MILE. Unit also includes 24-hour clock with meter minder and temperature indicator and countdown run timer.
New MANCHESTER CODE encoder.
NEW STYLE Two-way, window mount SUPER EXTENDED RANGE transceiver antenna module.
One 5-button extended range FM, standard 900-megahertz SLIDE COVER remote transmitter.
SIS-11 Super Intelligent Sensor with dual stage shock / glass sensitivity.
Discrete Temperature Sensor that communicates in-car temperature with LCD remote.
Window-mount Knock Sensor for driver paging.
Plug-in super bright mini-BLUE LED and push-type valet/override switch.
TWO-WAY O.L.E.D. REMOTE OPERATION:
5-button configuration with selectable Button Lock to prevent accidental mis-use.
Uses a rechargeable battery via Mini USB type connector w/ wall charger included.
Battery life indicator and power save mode
Full color (O.L.E.D. Organic Light Emitting Diode) with over 100 icons and animation screens.
Optional Two Car Operation with LCD transmitter only
Transmits on FM band and receives on FM band.
24-hour digital clock with count down timer for parking meter reminder. The clock doubles as a temperature indicator for monitoring in-car temperature. Displays in Fahrenheit or Celsius.
Multiple audible confirmation tones as well as vibrator mode for paging.
2-way Transmitter Range Check Indicator
ALARM FEATURES:
Six Channels of outputs (3 dedicated to lock/unlock, trunk and remote start / 3 auxiliary outputs)
Dedicated function buttons on LCD remote and 4-button standard remote transmitter.
Code learning / Anti-scan receiver with programmable code hopping.
Back-up memory system
Selectable Chirp Confirmation (OEM Style lock only chirp confirmation)
Comfort Feature with OEM systems having key / remote control power window roll-up
Dedicated remote panic and car locator
Passive arming by-pass from the remote
Parking light flash with dual polarity relay on-board
Plug-in dual stage SIS-11shock sensor with sensor by-pass from the remote
Starter disable output with relay and socket included
Dome light illuminated entry output
Dual polarity (+/-) door lock outputs with optional driver s door priority two step unlock
Additional positive and negative inputs
500 mA grounded outputs for starter disable and door lock/unlock
Programmable momentary, latched or timer on 3 auxiliary channels.
Programmable manual / passive arming with true last door arming with auto re-arm on
Programmable Single / Double Pulse Unlock (7 new timing adjustments)
Programmable Parking lights (flash or constant)
Programmable Pathway Illumination (on / off)
Programmable voltage sense for delayed dome lights (on / off)
Programmable horn and siren chirp delete
Programmable ignition control lock and unlock
Programmable pulse time for lock and unlock (.9 sec. / 3 sec.)
REMOTE CAR STARTER FEATURES:
5 On-Board Relays:
Ignition 1
Ignition 2
Starter
Accessory
Parking Light
3rd Ignition (-) output
Dedicated Second Start wire
Dedicated Ground out when running
GM- Non starter wire timing compatible
Ground when start (-) output
New Turbo Timer feature
2nd Accessory (-) output
Selectable one or two push Safety Start
Programmable gasoline or diesel with 10, 15, or 20 second Wait-to-Start
Hood pin switch safety input (pin switch included)
Selectable RPM / Voltage Start
TO VIEW MORE SPECS CLICK LINK BELOW
http://www.sonicelectronix.com/item_9303_AutoPage-RS-1000-OLED-with-ONE-MILE-RANGE.html
List Date: 11/19/2012
For more info, check out this listing in the Pro-Touring.com marketplace: AUTOPAGE RS-1000 1Mile - HIGH END ALARM (https://www.pro-touring.com/classifieds.php?mshow=listing&id=autopage-rs-1000-1mile-high-end-alarm-1465)
On Sale For: $220 + $0 Shipping
Retails for: $280 | You Save $60 | That's a 21% Discount!
https://static1.pt-content.com/images/noimg.gif (http://enthusify.com/protouring/listings/autopage-rs-1000-1mile-high-end-alarm-1465/purchase)
https://static1.pt-content.com/images/pt/2012/11/Q5R504zfzHeA2-1.jpg (https://www.pro-touring.com/classifieds.php?mshow=listing&id=autopage-rs-1000-1mile-high-end-alarm-1465)
https://static1.pt-content.com/images/pt/2012/11/G2S6AGXR7Gxk-1.jpg (https://www.pro-touring.com/classifieds.php?mshow=listing&id=autopage-rs-1000-1mile-high-end-alarm-1465)
