    Results 1 to 1 of 1
      Feb 2011
      southern cal
      anyone having issue's with a lingenfelter 58x24x conv module
      most of the time you need to crank the starter for along time to get the led to turn green for it to start or be in sync. also it will be running fine and the led night will go from green to red, but the motor will keeps running. we have good single coming IN to the conversion module on the crank and cam, but coming OUT the crank is good and the cam has a long delay under engine cranking.. we had changed the cam sensor and the PCM it made no difference.... thks
