View Full Version : Quick Ratio Steering Box???
novajess1972
11-07-2012, 06:46 AM
Want to firm up and quicken the steering on my 72 Chevelle. What is the stock ratio that I have....and more importantly....what should I be looking to upgrade to?
bret
11-07-2012, 07:17 AM
For a nice driver, I use a 14:1 ratio. My wife likes it. For an autocross car I use a 12.7:1 box. She thinks it's too hard to turn...I like it fine. Either will be a huge improvement from the OEM box.
novajess1972
11-07-2012, 07:36 AM
Thanks, Bret! Is it necessary to replace the entire link (rod) and rag joint, as well?
BTW - just watched the Ultimate Street Car Invitational...great job in your 33! That thing is kuh-wick!
Later-A-body
11-14-2012, 01:18 AM
I would contact Lee Manufacturing in Sun Valley, Ca. They are the best source. Send them your box and pick your ratio. I did that with mine. Went to a 12:1 ratio. Love it!
shep
11-14-2012, 04:09 AM
On the cheap, get a box out a 92-98 grand Cherokee, 12.7:1 43 deg 45Min You will need to adapt the hoses to AN or Lee sells press in adapters so you can use original hoses, and a rag joint from one of the following.
1977 thru 1982 Chevrolet and GMC C/K (2 wheel and 4 wheel drive) Pickup Trucks,
1977 and 1978 Camaro, Firebird, and Nova
1979 Nova
1983 thru 1986 Chevrolet and GMC C (2 wheel drive only) Pickup Trucks
Daren
11-14-2012, 01:30 PM
Will 3rd gen F bodies fit a Chevelle? I'm a big fan of the Iroc box. It's quick ratio, sends less boost to the steering wheel and allows for more road feel. I hear they are very similar in function to the Lee 670. $25 at a salvage yard.
I don't recommend ordering an Iroc box from a parts retailer as I have see the same part numbers for RS as Iroc-z. You'll likely get a regular 3rd gen box that fits Iroc-z and not an Iroc box.
11-16-2012, 09:56 AM
Standard third gens use a 14 to 1 ratio. Z/28's use 12.7 with firm valving but the IROC & TA use 12.7 with extra-firm valving.
regal454
11-16-2012, 10:27 AM
Does anyone know of a source to specifically get the IROC/TA box with the firmer valving? I was looking at Rock Auto earlier and it appears they dont specify these boxes seperately.
Daren
11-16-2012, 01:12 PM
I'd like to know too.
The gold standard now is to find a salvage yard with an IROC/GTA in it. Proceed to nab box.
nicks67camaro
11-16-2012, 01:37 PM
I have this in my car. I think it will work for your application. I needed to do a hybrid rag joint but it worked. the ratio is decent and the feeling is nice. I have this running with a KRC pump, remote reservoir, and a power steering cooler all with braided AN lines and works great.
http://www.ebay.com/itm/Lee-4001-14-7-1-35-14-1-Steering-Box-235-Valve-NASCAR-/150262333677?pt=Motors_Car_Truck_Parts_Accessories&hash=item22fc5540ed&vxp=mtr
LT1Nova
11-16-2012, 03:13 PM
I just went through this with a buddy. After looking on a couple camaro sites we determined the FE2 firm suspension option was the one to get as it is 2.25 turns lock to lock and should be the firmer input.
When I bought the one for my Nova I was told just to look for one with the raised Z cast on it which can have different guts.
I got a new rag joint and had pure choice make me some lines. For his we found a local parts/hydraulic store that makes custom hoses. This will work out well for his 4 wheel disc conversion as well.
Borre
10-26-2016, 11:09 PM
http://www.onallcylinders.com/2014/06/20/ask-away-jeff-smith-whats-right-steering-box-early-chevelle/
AngryIrishman
10-29-2016, 05:01 PM
what makes the 12.7:1 harder to turn than the 14:1 ratio? what would be a good ratio for a car that will be used for road racing and reckless driving on public roads?
pitts64
10-30-2016, 11:40 AM
4435
