View Full Version : 2nd gen subframes
zamora7
10-28-2012, 06:52 PM
I'll make this quick and easy. I poested this on another section so ill give it a shot here. My question is, is there a difference between subframes from a v6 firebird and a trans am? Thanks for any input.
formula350
10-28-2012, 07:33 PM
They are the same for all second gen firebirds and camaros, except the front end changed mid 75, meaning tie rods, idler arm and so on.
zamora7
10-29-2012, 09:13 PM
Ok cool. Thanks for the help. Im stuck between buying a v6 firebird for pretty cheap. But today i found a 1980 t/ a, t tops, 77 front end, shaker scoop/hood, rebuilt 327 on it for an extra grand. I have a subframe with some goodies on it already that i woild be throwing on either one. Looking forward to that. :D
BonzoHansen
10-30-2012, 07:17 AM
Subframes should be the same in those cars. Pre 75 frames are different. You may run into linkage differences. ps box lines are o-rings iirc 79 and up at least in camaros. Camaros may have differences in linkages too. The was a wheel bearing change at some point too.
