View Full Version : The Most Detailed LS3 In The Universe!
Al Moreno
10-27-2012, 09:11 AM
Hey guys, though I'd post a few pics of my sons project. It's a Gen 5 Camaro SS hes been working on.
On the performance side:
It's been bored and stroked to a 418, 11.4.1 compression, heads massage by Lingefelter, GT11 Lingenfelter cam, CP pistons, Lunati crank and rods, Meizire Electric water pump, Innovators West 8 rid front drive, Turn One power Steering pump, Every freakin bolt inside and out has been replaced with ARP, Pure power billet oil filter, Katech tensioner, Improved Raving valley baffle, ported intake and throttle body, etc, etc...
On the attention to detail:
The entire block, both inside and out along with the cylinder heads have been completely grounded smooth. All the accessories front drive brackets and the motor mounts were completed sanded and powder coated in "Anthracite". The oil pan, valley tray and timing chain cover powder coated in texture black. The thermostat housing powder coated onxy, intake in a gun metal gray. The block, heads, alternator, ac compressor, power steering pump all sanded down of any casting and painted BMW "Frozen" gray It's a gun metal gray with flat clear). All the pulleys were given a brush finish. Ring Brother washer for the intake bolts and throttle body, Lokar dip stick, etc, etc ......
There is a lot more but you get the idea.
Here's a couple of pics:
https://static1.pt-content.com/images/pt/2012/10/IMG_1295Edit2-1.jpg
https://static1.pt-content.com/images/pt/2012/10/IMG_1304Edit-1.jpg
After relocating the factory EVAC solenoid and negative battery cable that mounted to the front of the cylinder head, the 4 factory bolt holes on the were no longer needed, so they were welded in and the face re-milled.
https://static1.pt-content.com/images/pt/2012/10/0286-1.jpg
The factory vapor tube was replace with XRP AN lines and fittings.
The intake might be replacing the intake for a carbon fiber unit.
https://static1.pt-content.com/images/pt/2012/10/408696_483195951704965_338210126_n-1.jpg
Motor mounts with Prothane bushings.
https://static1.pt-content.com/images/pt/2012/10/IMG_1309Edit1-1.jpg
srh3trinity
10-27-2012, 09:27 AM
Speechless! Great attention to detail.
garickman
10-27-2012, 09:42 AM
What he said.
dan777
10-28-2012, 08:11 PM
That, my friend, is a work of art. Gorgeous!! Now I want to see the car!
Dan
LS1-IROC
10-29-2012, 02:38 AM
Awesome! It's a shame most of that work will be hidden in the engine compartment though.
Al Moreno
06-20-2014, 06:44 PM
Hey guys its been a while since I've updated this thread. Here are a few random pics..... will be dubuting in the Derale booth at SEMA. You can see the full build by goggling G5.R
https://static1.pt-content.com/images/pt/2014/06/G5R_frontview_Final_002_WEB_zps288eef6b-1.jpg
https://static1.pt-content.com/images/pt/2014/06/201406110646072_zps7c27e22e-1.jpg
https://static1.pt-content.com/images/pt/2014/06/IMG_6117_zpsdeca1afb-1.jpg
https://static1.pt-content.com/images/pt/2014/06/IMG_6078_zps5324d81e-1.jpg
https://static1.pt-content.com/images/pt/2014/06/008_zps3e4f1ce7-1.jpg
https://static1.pt-content.com/images/pt/2014/06/013_zps180a735d-1.jpg
https://static1.pt-content.com/images/pt/2014/06/IMG_0869_zpsb44c550a-1.jpg
71maroesteban
06-21-2014, 12:35 AM
My god that's beautiful
Jamess113
06-21-2014, 03:41 PM
Wow Al !!!!!That looks unreal!
raustinss
06-21-2014, 08:22 PM
Guys slide over to. Lateral-g.net, way more info and pictures. Same thread name too
benno505
06-22-2014, 05:19 AM
going to be driven hard or is it a trailer queen?
srh3trinity
06-22-2014, 07:24 AM
If I remember correctly, the plan is to drive it hard. It has Toyo's on it and I don't think those would be my choice for a trailer queen.
HellPhish89
06-24-2014, 03:00 PM
...i want that master setup...
that twin TB intake should be a very stout setup.
HellPhish89
06-24-2014, 03:37 PM
seeing as you wanted to lose 400lbs.. why no acid dip?
WallaceMFG
06-24-2014, 04:07 PM
That car is so good looking I'd be afraid to drive it!
moreHP
06-25-2014, 07:58 AM
*Sigh* further proof my car is a piece of crap! LOL!
