johnnyt1967
10-15-2012, 03:55 PM
Hey guys I need you help! I recently purchased ridetech's stage 2 coil over setup for my car. I am having an issue with the ford 9" rear that was built for my car. It is missing the bracket that ridetech's lower shock bracket mounts to. I would love to find a pre-fab bracket that will replace the stock 67' mounting brackets that i can buy and weld on to my rear. The other issue is if i weld on a bracket to the rear the trailing arm will need to slide over to the factory loaction so i can mount a sway bar to it. will moving the arm bind the suspension? I know it is hard to understand without being under the car but i hope these pictures will help..... 6624666244662476624866245
