View Full Version : 1967 chevelle with ford 9" ridetech suspension
johnnyt1967
10-15-2012, 03:55 PM
Hey guys I need you help! I recently purchased ridetech's stage 2 coil over setup for my car. I am having an issue with the ford 9" rear that was built for my car. It is missing the bracket that ridetech's lower shock bracket mounts to. I would love to find a pre-fab bracket that will replace the stock 67' mounting brackets that i can buy and weld on to my rear. The other issue is if i weld on a bracket to the rear the trailing arm will need to slide over to the factory loaction so i can mount a sway bar to it. will moving the arm bind the suspension? I know it is hard to understand without being under the car but i hope these pictures will help..... 6624666244662476624866245
johnnyt1967
10-17-2012, 01:11 PM
update! ridetech was awesome and called me back about this issue. the found a bracket that they have that fits this rear. they have been awesome to deal with on this issue. Jeremy said he would call me back on the matter and held up on that! Great customer service so far. I will let you all know how the install goes. thanks
coolwelder62
10-19-2012, 02:52 PM
The RideTech folks are FirstClass.None Better.Scott Mock Ridetech Dealer.
