View Full Version : Ez302 1969z
lftnwhls
09-25-2012, 03:32 PM
65177
So I have finally started the transformation of my 1969 Z28. For the last 10 years I left the 302 sitting on the shelf and have had various street/strip motors in this car. The last time the car was driven it went 10.8@126MPH with a very mild 540. I have decided that it is time to restore the car with a modern twist.
lftnwhls
09-25-2012, 03:49 PM
65181
The Tear Down. The car looked like this on one Saturday morning.
lftnwhls
09-25-2012, 04:14 PM
The car came apart very easy as it in pretty good shape other than the paint was cracking.
We got the complete interior and drive train removed.
lftnwhls
09-25-2012, 04:24 PM
I removed everything then mounted it on the rotisserie and prepped for Soda Blasting.
65188
lftnwhls
09-26-2012, 04:31 PM
Car stripped then cleaned. Then taken into the paint booth with acid etching high build epoxy primer.652406524165239
Rybar
09-28-2012, 02:09 PM
Looks like a solid shell you have there. That sure helps when doing a full build. Got any specs of what you are doing parts wise?
lftnwhls
09-29-2012, 05:47 AM
I am wanted to put it back to more of a long distance street car that we can drive to car shows comfortably. My wifes big thing is she doesn’t want to have to take a shower after being in it.
My last motor was extremely fun on the street but if you didn’t smell like gas you smelled like burnt rubber.
So I have decided to freshen my 302 with a hydraulic roller cam
EZ-EFI.
Tremec 6 speed I still have the Muncie.
Vintage air
DSE Mini Tub and 2” drop
17” Billet Specialties Vintec all around
approx. a 325 wide rear tire.
I have the car so far apart it doesn’t make sense not to replace all of the wearable parts. Its getting a full redo. This was a running and driving car but I am amazed how much of it is not being reused.
65373
diesel25lrs
09-29-2012, 06:01 AM
Let the "Snowball" begin! Lol... This is exactly how i started out about 15 months ago... Just a little refresh & paint job... HAHAHA... You had better leave this site before you lose your wallet @ life savings!
Nice project & good luck with the build-solid start!
ChevelleNV
09-29-2012, 08:50 AM
Wish someone gave me that warning two years ago....I be a lot richer now. :)
lftnwhls
11-30-2012, 04:50 PM
Frame and suspension back from Powder coating. It turned out Great!
The body is now fully primed inside and out.
WS6
11-30-2012, 05:37 PM
Glad you're keeping the 302. It's a great motor that's just not really seen any more. Good luck!
lftnwhls
12-30-2012, 02:41 PM
The suspension is all back together just have to add the Wilwoods.
FRENCHBLUE72
12-30-2012, 03:49 PM
Damn not many people running the 302 chevy anymore nice job..
Todd in Vancouver
02-24-2013, 11:44 AM
Really nice car, I absolutely love the earlyZ's. looking really good!
lftnwhls
10-26-2013, 12:02 PM
I traded up to the EZ EFI 2.0 so that I could have the advantage of the self learning timing control. Improved monitoring, tuning and fan control. Hopefully on the dyno this week.
lftnwhls
10-26-2013, 12:11 PM
Studded
wfo guy
10-26-2013, 03:02 PM
Good build. You have many months between posts. Is the body completed?
no go nova
10-26-2013, 03:44 PM
Whats your power goals for the 302?
lftnwhls
10-26-2013, 05:06 PM
I think the motor will make 300 HP or more. I want it to run smooth and responsive more than the BIG radical power. I will post the #'s when its done. With the EFI and the T56 Magnum I think it will be a fun enough long distance car. The car has not been painted yet. I have changed so many things there has been a lot of mock up. I also did the DSE mini-tub.
lftnwhls
10-26-2013, 05:10 PM
Attached is a pic of a Fiske 18" wheel with a 345 tire. I will be using something else just wanted to see what the max tire I could fit in it.
uxojerry
10-27-2013, 04:10 AM
Send the heads and intake for porting and you'll get another 50hp+- out of it. Nice Build!!
rwcstang
10-27-2013, 10:40 AM
very nice build!
lftnwhls
12-25-2013, 06:25 AM
Here is a quick Video of my DZ 302 with the Fast EZ EFI 2.0. It has 30 over Forged Pistons, Scat Rods, Studded top and bottum end, Hydrualic Roller Cam, Comp Stainless Roller Rockers, 10:1 Compression. The little Motor made 340Hp @ 5700 and 333TQ @ 4500. I just want it to be a strong reliable and decent on fuel.
I think it will work great with the T56 Magnum
Z9q69HvkpQI
