View Full Version : Speed Tech Torque Arm or Ridetech 4 Link on 1st Gen Camaro
Smoker03
09-21-2012, 08:27 AM
What are the benefits and disadvantages of the two systems? I'm pretty split on which direction to go. I know both have excellent quality, customer service and the products work.. Has anyone had experience with both systems that can make some comparisons?
BMR Sales
09-21-2012, 01:25 PM
We offer bolt on Torque Arm kits for 67-81 F-Bodies & 68-74 X-Bodies with 10 bolt & 12 bolt rears.
https://static1.pt-content.com/images/pt/2012/05/kitpricing-1.jpg
We also offer kits for the guys who want a Ford 9" that includes a bare Strange housing for $600 more. Take a look at the link below detailing an install that a member here completed with our Ford 9 in. kit in his 1973 Firebird:
https://www.pro-touring.com/showthread.php?80483-BMR-Torque-Arm-Installed-on-my-73-Firebird/page2&highlight=TORQUE+ARM
Here is a video of a customer who got 2nd place in Street Machine Class at Kansas Good Guys recently. He is running air over shocks and had not adjusted the roll center via Watt’s Link….. he should be able to cut about 2 seconds off this time just by addressing these issues.
http://www.youtube.com/watch?v=TLQ5sk23b8Q
Here is a VERY informative tech article written by our R&D manager explaining what it does:
http://www.chevyhiperformance.com/tech/chassis/suspension_steering/1206chp_torque_arm_suspension_systems/
Let me know if you have any questions about the kit we offer.
Bad94
09-21-2012, 01:28 PM
I have the air bar in my car and im happy with the ride.
Smoker03
09-21-2012, 01:30 PM
Do you have any lateral movement?
killer69
09-21-2012, 02:02 PM
No disadvantages to speak of with the Speedtech Torque arm. Easy install. lots of Room for 3" Exhaust OVER THE HOUSING and have a low ride height with no issues. No floor cutting, easy set up.
Includes Articulink trailing arms with Delrin bushings. billet aluminum pinion mount and all hardware obviously
1999.00 with Qa1 shocks and a new 9" housing is 710.00 with all the brackets welded on. any width you require, we can help you with that as well as the correct wheel fitment for your car. 345's will fit on a 67-69 with mini tubs.
add 250.00 if you want to upgrade to Ridetech shocks. Still a better value.
https://static1.pt-content.com/images/pt/2012/09/DSC_1424-1.jpg
https://static1.pt-content.com/images/pt/2012/09/DSC_1406-1.jpg
https://static1.pt-content.com/images/pt/2012/07/Speed_Tech_59-1.jpg
https://static1.pt-content.com/images/pt/2012/09/DeansCamaro005-1.jpg
https://static1.pt-content.com/images/pt/2012/09/DSC08617-1.jpg
any specific questions give me a call.
Smoker03
09-21-2012, 08:28 PM
Thanks Blake. Anyone have first hand experience with these on ride quality and installation?
I do.
ride quality with any suspension is more dependent on shock valving than anything else. with that being said, I can adjust my ridetech tripples to make this suspension ride like grandpa's caddy, carve like a new ss or rattle your dental work loose.
I did my own install on the garage floor and it was one of the easier rear suspension installs that I have ever done. and the required welding is easy to do. while bmr may offer a true bolt in kit, I took the money that I saved by buying the street and track proven speed-tech kit and upgraded my shocks to those badass ridetech tripples. they are an incredible tuning aid be it for ride quality or performance.
if you are going to farm out the install, the welding will cost little extra. if you are going to do your own install and have no friends that weld, welding equipment or skills, you can get everything ready and get a mobile welder to come by and weld it. around here I could get it done for about a franklin if I had everything marked, cleaned and ready.
I too thought about the ridetech 4-link. ridetech makes awesome products, and it is a great bang for the buck. but I'm just a tq arm kind of guy. I also love the fact that no rear swaybar is needed with the speed-tech kit.
diesel25lrs
09-22-2012, 07:50 AM
ST for the win! Easy install! Performs very well on the street & track!
Smoker03
09-22-2012, 08:47 AM
I've been leaning towards the ride tech for the ease of installation, but it looks like the hardest part of the Speedtech kit will be cutting the factory leaf spring mounts off and spending some time with the grinder.
diesel25lrs
09-22-2012, 09:12 AM
Cutting the factory leaf spring mounts off??? I don't remember doing this... Your torsion bar goes into the front half & you dont touch the rear hole... Is this on a camaro or nova?
killer69
09-22-2012, 11:16 AM
NO CUTTING REQUIRED! lol honestly you may want to remove the factory pinion snubber
Smoker03
09-22-2012, 12:59 PM
What about the spring pad mounts on the rear end housing? Do the new brackets bolt to those or do they need to be removed. I will be using the factory 12 bolt housing. Do you have install instructions you can post. I did a search on the Speedtech website but they were not listed.
killer69
09-22-2012, 04:02 PM
OH those brackets, sorry didn't understand, yes those need to be welded on, 90% of the time guys are buying the suspension with a new rear end as well. you still need to weld the upper brackets on thr ridetech setup as well, so no real differance there you have to weld 3 brackets on ours and 2 on theirs.
we have a shop in northern LA that could weld the brackets on your rear housing for probably for 120.00 if that makes it easier.
Smoker03
09-22-2012, 05:21 PM
The weldings not an issue, I'm a certified welder, just wanted to know if I had to cut the old leaf pads off and weld the new brackets on. The torque arm is the way I would prefer. Thanks again for all the info
Smoker03
09-24-2012, 06:06 AM
Has anyone noticed any wheel hop issues under acceleration or braking? My biggest issue right now is wheel hop under acceleration. I am running NT01s, so I have good grip and just over 400hp at the tires. I have DSE leafs and GW delalum bushings and have been contemplating a set of caltracs due to the issue, but dont want to sacrifice the handling of the car. I would rather go to the next level if it will make the difference. I didnt think a watts link would help with spring wrap.
killer69
09-24-2012, 07:12 AM
I have NEVER had any wheel hop. acceleration or braking, my car actually stops really well i can dial alot more rear brake into the car than was expected.watts link has nothing to do with wheel hop you are correct.
69bigblock
09-24-2012, 12:52 PM
Can you use shockwaves with the speedtech kit?
killer69
09-24-2012, 01:05 PM
Yes the 4" diameter 7000 series just have to be carefull of the clearance with the rear end housing.
Mick-
05-15-2014, 10:45 PM
Hi, First time poster and have been trawling through some threads and thought i would resurrect this one,
I'm in aus and doing a rebuild on my 69 camaro, basically im after a rear suspension package and from my research this has come up as one of the better options, im interested in getting my hands on one of the speedtech torque arm kit but can't find any resellers in Aust, is it possible to get these kits sent to Australia. ???
Juzzy
05-16-2014, 02:45 AM
Hey Mick, I'm in Aus as well and I have a speedtech kit in a crate along with a heap of other stuff almost at my door. Get in touch with Jay at Speedtech and he will sort you out. Good thing is that I'm able to get the whole kit engineered in Aus so it's legal too.
Mick-
05-16-2014, 03:23 AM
oh great are you east or west coast ?
Also how did you get in contact with him ? I tried contacting him through speedtech website with no response.
killer69
05-16-2014, 07:57 AM
you can email direct to
[email protected] or me
[email protected] or call 435-628-4300 Jay is usually here a bit later due to the time differance
Juzzy
05-16-2014, 04:05 PM
I'm east coast. Quite a few people on both sides of the country are installing the stuff. The service has been excellent. So much so that it's easier to deal with Speedtech than some suppliers here. If you're looking for shipping, Speedtech can do it for you as well. I used USA to AUS as i had a decent size crate and the prices were good. Blake, your gear seems excellent and my engineer was impressed with the pics at least. I spent alot of time sourcing gear with Jay and he was a fantastic help. I'll be ordering more once I move house and get the car on 4 wheels again.
killer69
05-18-2014, 07:54 AM
Glad the engineer is impressed......... no reason not to be. Thanks for the business and confidence, We ship LOTS of product to Aus. and Jay has really worked hard to figure out the shipping, We now have a great deal with UPS so you get parts in about a week at a reasonable cost.
Mick-
05-18-2014, 03:20 PM
Great thanks so much guys i will get in touch with speed tech today and start organising an order.
Henshman
01-31-2015, 07:30 AM
Will this setup fit a 3rd gen nova? Looks like the pics are of a 3rd gen...
Currently have a Hotchkis"stock" setup, ford 9" and I am hoping to minitub the car and install a 4 link...thanks matt
Henshman
01-31-2015, 07:57 AM
Just checked out the page...looks like you have it all for the nova!
