View Full Version : Holley LS accessory brackets.
Samckitt
09-19-2012, 04:34 PM
Holley has recently released a slew of accessory brackets for the LS motors to aid in swapping to other vehicles. I like the look of their high mount AC brackets. Gets it out of the way while still looking like the other cast brackets.
http://holley.com/types/LS%20Accessory%20Drives.asp
09-19-2012, 10:08 PM
Wish we had pictures of it installed.
72Z/28
09-19-2012, 11:07 PM
You are right I also would like to see how it fits compared to KWIK AC bracket, which I currently have
garys 68
09-20-2012, 02:57 AM
The Holley AC bracket I've seen is made to fit the R4 compressor, not a Sanden.
hifi875
09-20-2012, 04:03 AM
They will offer both. And IMO it looks better than the qwik especially if you r running corvette accy system because it matches exactly the vette alt bracket and doesn't look like a bunch of billet flat stock that's bolted together
Samckitt
Bracket pictured above is for the Sanden compressor. Pictured below is for the R4 compressor.
Not a real picture, but this shows the Sanden compressor bracket installed.
Got that image from this document:
http://www.holley.com/data/Products/Technical/199R10614rev1.pdf
garys 68
09-20-2012, 04:55 AM
Good to see another option. When I did my first swap S&P was about the only game in town, and they were expensive. I ended up making my own brackets.
Kwik went on my second swap. Thinking I'll go with the Holley brackets on the next. They do look good and are priced right.
parsonsj
09-20-2012, 05:07 AM
Any idea of availability? Buy now, have it ... when?
Samckitt
09-20-2012, 05:10 AM
The R4 compressor bracket can be ordered now from Summit. Dunno if it is really available yet.
So my question is, since I have to buy a compressor anyway, which is better & why? Car originally had the R4 style compressor.
Samckitt
09-20-2012, 05:11 AM
oestek
09-20-2012, 05:37 AM
These are nice, and they are not expensive, either.
lolife55
09-20-2012, 07:29 AM
Bought the R4 brkt couple weeks ago from Pace and had it in a couple days. Installed but still need to pick up a compressor. Nice piece that fits well with the vette brkt.
parsonsj
09-20-2012, 07:50 AM
We installed the KWIK on the 69 Camaro/LS3 here in the shop, and it's ugly. The cast Holley part looks better. Maybe I'll give Pace a call.
gray86hach
09-21-2012, 04:41 PM
Robin L. told me at ls fest they were on the shelf in BG so getting them is not a problem. They had them on display and they are nice looking
Tim
rocketrod
09-22-2012, 02:58 AM
Can you post a pic of the installed bracket?
I really like this bracket. I wish they would also make them for the smaller SD-7 compressor.
Here are the links and prices listed in Summit.
AC Bracket $129.95 - http://www.summitracing.com/parts/HLY-20-133/
Alt/PS brackets 149.95 - http://www.summitracing.com/parts/HLY-20-135/
AC & Alt/PS bracket kit $249.95 - http://www.summitracing.com/parts/HLY-20-131/
Samckitt
09-22-2012, 05:40 AM
20-134 fits an SD7 compressor.
CarlC
09-22-2012, 09:06 AM
I wonder what the belt loading and tracking will be like. The factory arrangement uses a separate belt for the A/C. The W/P wrap % is a bit concerning as well if the above is correct.
diesel25lrs
09-22-2012, 09:15 AM
I have a brand NIB vette compressor im not using if your interested- PM with an offer!
Samckitt
09-22-2012, 09:48 AM
There is very little difference in the belt pully coverage on the Holley setup compared to the stock GM setup from the factory. From the factory there is a tension pulley at the location in front of passenger side head.
Stock GM Corvette setup"
https://static1.pt-content.com/images/pt/2012/09/185724d1246383096helpfulaccessorydriveco-1.jpg
gray86hach
09-23-2012, 05:34 PM
Holley has had this bracket on their test wagon since before power tour. I don't think they have a issue with the WP slipping
Tim
Kenova
09-24-2012, 06:32 PM
If someone were worried about the water pump slipping they could always relocate the power steering reservoir and install another idler pulley in it's place. Keep the idler pulley as close to the water pump as possible and you would lose very little wrap on the alt. pulley.
Ken
Samckitt
02-15-2013, 06:48 AM
Bringing back an old thread. Anyone have pros/cons on the R4 style compressor compared to the Sanden unit?
Chev67
02-15-2013, 06:23 PM
How about with high rise valve covers, any interference like with the corvette alternator bracket?
Bowtie racing
02-19-2013, 12:14 PM
Spot on!
shawnvan
03-02-2013, 01:58 PM
The R4 pump cannot rev past 4000 rpms you have to create a device to shut it down using the tach as a switch. And it is ugly. Holly did not have the sanden available when I bought my setup so I found an adaptor kit from classic auto air to mount the sander sd5 or 7. The big downside to this setup is the f body steering pump setup doesn't work so you have to get the C5 setup. IMO I would go with the GMPP setup next time. But the quality and fit is nice.
