View Full Version : 345/30/19 on a cutlass
jmbamb455
09-13-2012, 06:44 PM
644276442964430Hey guys I dont post much but i thought u cutlass guys would like to know that a 345/30/19 will fit with a rolled lip, rims our 19×11.5 forglines with a 6.5 bc64427[ATTACH=CON[IMG]781
Loyaltyisking
09-13-2012, 06:58 PM
What about rubbing in cornering?? Have you tested it? I have some 11" wide with a 275, stretched a bit, but no rubbing in hard corners. Looks dope tho!
Oh i have a 66 chevelle.. I believe we have the same frame
jmbamb455
09-13-2012, 07:15 PM
Never been tested its a long ways from bein done but with the springs out ive laid it as low as it will go and its tight but a fair amount of room...and with the lips rolled if it ever touched the lip wouldn't cut the tire. Before i tore it apart it had a 315/35/17 that never rubbed without having a rolled lip. Your frame is different 68-72 our the same
ProTourGSX
09-14-2012, 10:47 AM
Bodywork looks good, wheels look really good, looks like it's coming back together, so far! Wish my GS was as far along as yours is, but I'm working on it! Keep us posted with updates (and pics)!
jmbamb455
09-14-2012, 02:04 PM
Its still a long ways from going back together I still need to weld the other quarter on and then its coming of the frame and the body is getting blasted and zinc coated. The reason the left quarter is shiny black is i found 2 rust free original quarters and before i welded it on i had a good friend of mine that is a excellent pdr guy remove the dents and dings so i put a quick coat of black on it to help highlight the dents..the gold is the original paint. Good luck on the G.S. I almost bought a skylark before i found the olds
724tim
09-14-2012, 02:57 PM
I like it alot thanks for sharing.
TimMC
02-24-2013, 07:07 AM
This is good to know starting to put together the list to build mine. Any updates?
csouth
02-25-2013, 11:31 AM
I'm no expert by any means, but that car does not appear to be sitting on its own weight in a couple of those pics. Remember you still have to allow for up and down suspension travel and body roll to some extent. I have never heard of anything more than 315 fitting without out work, but my GF tells me I have selective hearing...lol
jmbamb455
02-27-2013, 08:11 PM
I've checked the clearance with the shocks and springs removed with rear end bottomed out to the body and there's at least 1/2 inch of clearance....I trimmed the wheel well lips down to 3/4 of a inch and rolled them as flat as possible... I think the nittos tend to run on the small side in width also. It takes some patience to roll the lips on these older thick metal cars...I couldn't get it to roll until I heated it with a torch...I wouldn't recommend it on a painted car
Glock 18
03-01-2013, 05:17 PM
The tire/wheel combo is kick ass! What tire is that? What Forgeline wheel is it? I'm guessing the frame is the same as my '69 Chevelle. Thanks!
alowerlevel
03-02-2013, 09:55 PM
Tires are Nitto Invos, and the wheels look like they might be Forgline S03s
agent29
09-23-2013, 07:08 AM
[QUOTE=Loyaltyisking;934803]What about rubbing in cornering?? Have you tested it? I have some 11" wide with a 275, stretched a bit, but no rubbing in hard corners. Looks dope tho!
Oh i have a 66 chevelle.. I believe we have the same fram/QUOTE]
Looks nice! What are you runnng in the front?I bought 19x10 for the back and 19x8 in the front looking a good tire combo? Rims are the boze lateral gs
chevelletiger
09-23-2013, 01:07 PM
Looks nice! The checking up and downs not a bad idea on rubbing,but did you move the axle from the center of the axle,or one side at a time?
RaiderLSX
03-04-2014, 07:31 AM
Any update on fitment? Or on the car overall? Nice build, I'd like to follow until completion.
cutlassfan
03-07-2014, 06:46 AM
I am very interested in this build as well...love the 19's in either a 335 or 345...I would love to hear feedback on drive ability ...they need to fit under the wheel well as well...I have heard of 305 18's fitting nice on a 10" wheel but not this big without notching the frame....hope to hear back soon...thanks for the wheel back spacing details
csouth
03-08-2014, 08:05 PM
Its been over a year since the OP has even logged in here, I wouldn't expect much feedback. My advice would be to expect the unexpected. These are 40yo cars we are building and there is bound to be some inconsistency. If I were putting a 11.5" wheel and a 345 on my car I would plan on notching the frame at a minimum.
cutlassfan
03-10-2014, 06:30 PM
Thx I appreciate your feedback .... Thought notching the frame would be a must... It's guys like you that keep these threads alive....thx
jmbamb455
03-11-2014, 06:07 PM
Sorry for the late response... I didn't notch the frame...I trimmed the wheel well lip down to 3/4 inch and rolled the lip n slightly stretched the quarte. I ran a 17/11 on a 315 drag radial for years with no problems. I would recommend finding a used 345 and test fit...u will definitely need to roll the lip and it takes heat and a big hammer on these old cars
jmbamb455
03-11-2014, 06:28 PM
91689Not really any updates besides that I smooth the firewall. Haven't worked on it all winter..ain't much heat in my Buddys shop. The fronts are 19×9.5 on 275/35/19 I'll have to check the back space..I haven't had the front end on my car since I've had the rims..that is a pic of the fronts on a non lowered 69 chevelle
jmbamb455
03-12-2014, 05:10 PM
9180891809My old setup 17×9.5-275/40/17...17×11-315/35/17 forge lines
cutlassfan
03-23-2014, 01:05 PM
Keep posting I like where you are going with this car and looking forward to the new 19" wheel pics...I am interested in seeing how the car sits...
JJ 86
11-08-2023, 11:46 AM
Has anyone else mounted 345's on 70-72 Cutlass? Not sure if the OP is still active but it would be nice to see updates on this build.
