jolt
09-04-2012, 10:56 AM
I have a 2005 LS2 all factory corvette including programmed pcm and harness in a Gen II camaro. Car ran perfect until I disconnected and remounted the gauges in a new carrier. NOW- when the key is turned on.. fuel pump runs and primes as it should.. car starts and runs perfect.. for abourt 20 seconds and then starves for fuel. Power to fuel pump is being shut off by the pcm I guess... but the car has oil pressure.. so I doubt it is oil press safety switch. All gauges are wired correct and work correct. Any one seen this before ? ideas ?
Thnx~ Jolt
Thnx~ Jolt
