    Results 1 to 12 of 12
      Feb 2007
      3rd gen nova 17in wheel specs that are on the road
      Im looking at getting some 17in wheels from vintage wheel works for my 72 nova. I would like to see some specs on 17in wheels for a 3rd gen Nova with stock sub-frames and stock rear tubs with lowered suspension. My car will have C5 front brakes as I know with stock drums hubs it moves the wheel out a little but not much.
      I would like to see specs that are on the road with no issues. I have done a lot of searches and really want to know what people are running in one forum
      my current idea would really like a 8in wheel on the front but want a safe size
      17x7 4.5bs with 235/40r17
      17x9 5.75bs with 275/40r17
      Brandon Slater
      1979 Z28
      1972 Nova
      2015 2500 silverado crew cab duramax
      Mar 2010
      South Central Ky
      Quote Originally Posted by brownz View Post
      From all my research "Steve's Nova Site", looking at the same for my car too....
      Up front: 8" wheel with 4.75" bs and up to a 245-45-17"
      Out back: 9" wheel with 6" bs and a 275-40-17"
      Hope that helps.
      Feb 2007
      I have also looked around and found that the 8in wheel with 4.75bs is a option. as for the 9'' with a 6in I have found most people run that bs with a 9.5'' rear wheel...
      Maybe be someone that is running sizes like that will give some info about how it works on the road and if they have any issues.
      Brandon Slater
      1979 Z28
      1972 Nova
      Dec 2011
      San Diego, CA
      looking at specs aren't going to get you far you need to measure you're own car as almost every nova i've seen measure's up differently
      the wheels i was looking at for my 72 were:
      18x8.5 5.25" BS front or +12 offset 245/40/18
      18x9 5.5" BS rear or +12 offset 255/40/18
      and the set i'm picking up today are
      front 17x8 with 5.5" BS 245/40/17
      rear 17x9.5 5.5" BS with a 255/40/17
      and both sets would fit... picking up the second set cause i found a killer local deal on them
      make sure you measure i used the homemade wood tool DIY on stevesnovasite to measure my car and it worked great to check everything and cost me nothing as i had a 2x4 laying around just make sure you use the right measurements for the wheels and tires you want to use and when you measure for the tires find out its section width not the contact patch width
      my car will be lowered 2+inches on ridetech coilovers and rear 4link
      here's the DIY hope its ok i post it here as its quite helpful
      http://www.stevesnovasite.com/forums...d.php?t=174839
      -Blake
      yellow 72 nova in San Diego
      Feb 2007
      Thanks for the link. really looking for sets that are on the road with no isues. I will measure my car before I order but want to see what people are running without any rubbing problems.
      Brandon Slater
      1979 Z28
      1972 Nova
      Dec 2011
      San Diego, CA
      i should have mine mounted and balanced in a few days ill let you know how they fit
      -Blake
      Feb 2007
      any updates Blake?
      Brandon Slater
      1979 Z28
      1972 Nova
      Hildebran, NC
      I have a set of Wheel vintiques 17in rallys on my nova.
      17x8 w 5.25bs front and rear. 245/45/17 KDW front & Rear.
      255/45 is ideal for the rear, but they dont make them in a KDW.
      Both front and rear are up in the wheelwells. I really like the look.
      My car is really low and they do not rub at all in normal driving.
      See my signature, or i can email you some pics.
      Also......235/40/17 would look like a rubber band.
      I started with 235/45/17 on the front of mine, but did not like the way it looked.
      It looked too small. I have the 235/45/17 KDWs for sale if you go for the 7" wheels!!
      I also did a million searches before i bit the bullet as well.
      Good luck,
      Randy
      Cincinnati Ohio
      I had 17x9.5 with 6" BS with a 275/40/17
      1972 Nova Ridetech, Forgeline, Falken Tires, Wilwood, Bowler Performance Transmission, Lingenfelter Performance Engineering.
      Feb 2007
      Dan I wish you still had them so I could test fit LOL
      from what I have found the sizes that I will go with unless I find some more info that shows this will not work.
      17x8 with 5.0bs and a 245/40 ( front )
      17x9 with 5.75bs and a 275/40 ( rear )
      Brandon Slater
      1979 Z28
      1972 Nova
      Cincinnati Ohio
      Wanna see if my new ones fit? LOL
      Feb 2007
      Quote Originally Posted by Bad94 View Post
      If I get them to fit can i keep them???
      Brandon Slater
      1979 Z28
      1972 Nova
