Results 1 to 20 of 26
The art of purge welding( back purging)
Me (most people call me Eric) parsonsj(most people call him John I believe) got into a discussion on another thread about purge welding stainless tube and came to the conclusion that I share my knowledge.
A little backround first. I've been doing fabrication and welding for about 20 years. Have done sheet metal fab and tube, pipe work for most of those years and have learned quite a bit. Have been doing sanitary stainless tube for about 9 years now. I get to make some neat and nice stuff sometimes.
I'll start this with my welder I'll be using.
It's a miller Econotig I picked up used. Good welder for what I use it for.
I run an air cooled torch with a gas lens and 3/32 2% thoriated tungsten for most of the welding I do. And pure argon gas
I'll be using a piece of 2.5" 304L SS sanitary tube for this, with a ferrule on each side.
I'll purge weld one joint and just weld the other joint without a purge. The particular piece was an old product line and has a calcium build up that needs to be cleaned out in order for it to properly be purge welded
This is welded using a method called walking the cup. Where as you rest your TIG cup on the tube and literally "walk" it around the tube while welding. This does two things. Allows you to make a much longer weld before you need to reposition and will make a much more uniform weld. The less starts and stops you have, the better.
I like my welds nice and clean.
Here's the inside. Could have been less heat and there wouldn't be no sugaring.
Spin my piece and prep the other side for a purge weld. I keep a variety of different adapters for various tube sizes and different applications.
Most of my adapters have a quick connect for easy changes to other purge cap sizes.
When purging, you're removing all the atmosphere gases from the tube and replacing in with argon. You want to close off all other openings. I use tape or sometimes aluminum foil. Unfortunately I forgot my purge hose on a job so I'll continue this tomorrow and get a little more in depth on it.
Hope you enjoy.
