View Full Version : Drip rail removal
z0sick
08-20-2012, 12:34 PM
I'm no pro... just a guy in his garage. Never messed with a drip rail before and never done body work at all prior to this car, so take it for what it's worth (not much).
A good place to start with drip rail removal is with a decent drip rail.
After you find a decent drip rail, you'll need a good way to destroy them.
I prefer the grip and bend the hell out of it method.
After it's all bent, its time to chop. I took a page from someone else's book and did the chop/tack weld method. (6 inches at a time)
After the whole thing had been chopped off and tacked, I welded between the tacks and cleaned it up with a flap wheel.
End result = no drip rails...
Ron.in.SoCal
08-20-2012, 12:45 PM
Nice job! I remember doing it exactly as you did. Scared the carp outta me. :yes:
z0sick
08-21-2012, 04:43 AM
63599
DreKoushRanada
08-26-2012, 04:44 AM
I cant wait to start on mine. So once you bend the drip weld you will be able to see the seem you have to weld? I will be doing this with a 1970 cutlass.
z0sick
08-27-2012, 04:57 AM
What you see in the pics is exactly what it looks like. Once you bend it down there will be a little seam sealer and a joint of two panels. On the Camaro, the panels are offset by about 1/2". I cut about 5/8" off, welded, and ground smooth.
DreKoushRanada
08-27-2012, 03:31 PM
Thanks for the info. I hope to start on it this weekend.
DreKoushRanada
08-28-2012, 12:14 PM
Do you thing the Harbor Freight 90 amp flux core welder would be good for this project?
jlcustomz
08-28-2012, 06:20 PM
Flux core welding is quite messy for something you need nice like bodywork on thin sheetmetal.
blakes72x
09-03-2012, 11:37 PM
ok so this is definately now on my to do list
looks great
cwylie
04-15-2014, 09:50 AM
I want to do this but as everyone else said it scares the crap out of me. Anyone else have pictures of what they did?
minendrews68
04-15-2014, 10:12 AM
Man, I'm right there with you. Although I would like to have a little bit of a roll there at the place where you welded it. It scares me too, probably why I've not done it yet.
WallaceMFG
04-15-2014, 10:35 AM
I skipped the bending part when I did mine and just cut them off in small sections, but that way works too!
I've got some pictures of cutting mine off my 69 Chevelle in my build thread. I can put them here later if people want them here.
Here' the build thread: https://www.pro-touring.com/threads/105831-1969-Chevelle-quot-Cone-Smasher-quot
tigerhays
11-27-2014, 10:32 AM
Im rebuilding the corners of my roof just above the a pillars, I was considering cutting the drip rail off I have been trying to search and find this so I can see how it was done and finish look....I can not see the pics? can someone forward them to me? [email protected]
jlcustomz
11-27-2014, 04:41 PM
You can't bring back pics once the original poster removes them from an original source such as photobucket.
Here's a couple more threads on the subject
https://www.pro-touring.com/threads/43090-Need-Advice-on-Shaved-Drip-Rails-for-68-Camaro?highlight=drip+rail+removal
https://www.pro-touring.com/threads/85096-Shaved-drip-rail-bad-idea-for-rain?highlight=drip+rail+removal
tigerhays
11-28-2014, 05:14 AM
thanks I am still on the fence,I have a friend that is having his done as we speak...I guess I need to go see in person before I commit!
