    Results 1 to 4 of 4
      Aug 2012
      Build a box for my 69 chevelle
      Nothing to fancy, but i wanted some trunk for tools and groceries.
      Here are the plans i drew up.
      This should fit any A-Body from 68-72 seeing as they have the same trunk floor.
      Enjoy
      Feb 2009
      Laramie, WY
      I would actually go for a full sheet brace cut out. If your read the notes on bracing on the JL web site. you can never have too much. Even just using W0s.
      Tim
      1971 Buick Sportwagon pro-touring project. Buick 455 TH350, SPC front suspension, UMI rear suspension, KYB shocks, Slowly getting there.
      1985 Ford Crown Victoria 2 door next project.
      Jan 2011
      Boston, MA
      Quote Originally Posted by PT Sportwagon View Post
      Tim
      He already built it, so it's a little late to change the bracing now.
      I agree on the full brace, but you can also add a ton of strength and save some weight by using a full sheet and then cutting out a bunch 3-6" circles if you aren't trying to seal the left and right chambers from each other.
      Aug 2012
      Yeah i was thinking of bracing it with a full center section and routing out an upper area and lower area with a 2 in wall left in the center, top and bottom.
      I dont see any flex but im sure there is a little. It sounds great though.
