View Full Version : Oil pan clearance
snappytravis
08-09-2012, 05:35 PM
I have a ls3 with autokraft pan. It is installed in 69 camaro with art morrison front subframe, I used morrison adaptor plates with energy suspension mounts, It sits aprox 1/8 about the steering rack, super close, I am thinking of changing adaptor plates to the ones autokraft sells. I see some look like they are offset a little wich would put the pan up away from the rack, any good advice on this as to what you guys may be using in the morrison chassis.thanks
dhutton
08-10-2012, 05:01 AM
I used the stock F body pan with my Art Morrison subframe. That is what they designed it for as far as I know. At least that is what is in all the photos on their website.
08-12-2012, 10:09 PM
You should be ok, the rack doesn't move and any engine movement will be upwards.
