    Results 1 to 10 of 10
      Dec 2010
      69 camaro question
      I have a 69 that only has upgraded discs on the front and QA1 shocks. Everything else seems to be factory setup. I was looking at a set of Boss 338 20x8.5 with 245 tires and 20x10 with 275 tires. Will this setup fit? Do I need spacers? Or are they just too wide?
      Dec 2009
      Need to know backspace to answer your question. Also the 10" rear will be a problem unless everything is just right. Typically 9.5" w a 275 will fit a bit better.
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Mar 2010
      Fayetteville, NC
      69 camaro question
      I have 9.5 with 275 and they tuck nicely.
      Brian Peacoe
      68 Camaro Heidts Subframe and 4 link. 2015 LS3, T56.
      Dec 2010
      I am not sure the back spacing. I've looked on Boss website and I don't see the backspace info on there. Does anyone know?
      Mar 2010
      Fayetteville, NC
      69 camaro question
      I think mine are 5 1/2 in bs.
      Brian Peacoe
      Dec 2010
      What wheels are you using?
      Mar 2010
      Fayetteville, NC
      69 camaro question
      Boss 338. Gun metal gray.
      Brian Peacoe
      Dec 2010
      their website doesn't show a 20 x 9.5
      Mar 2010
      Fayetteville, NC
      69 camaro question
      I'm pretty sure that's what they are. I don't think they are an 8. That's what I have on the front with a 245. Unless they are 8.5. I'm sorry I may not remember correctly.
      Brian Peacoe
      Dec 2010
      can you post a pic of it?
