View Full Version : come on dse!
chevelletiger
07-28-2012, 09:15 AM
6248362484 they said these brackets are one off and no plans for production parts :-(
chevelletiger
07-28-2012, 09:21 AM
Sorry i forgot to add this is on a 70 chevelle.this is what i need it looks so damm trick!
Simmo
07-28-2012, 10:09 PM
Haha you're really not keen on the GW bracket are ya..f.air enough I guess. Gotta say that thing ^ looks solid!
Is it intended to run a reeealy long stock style spring or a coilover?
67bird
07-30-2012, 11:39 AM
How good of a fabricator are you? The reason I ask is you can get the coil over bucket from TRZ suspension for their front coilover kit and then drill the hole out bigger and install tabs for the coil-over. Check out their site.
chevelletiger
08-01-2012, 11:42 AM
Thanks ill look into trz,and yes im pretty good. With fabrication im a machinist by trade not cnc thou
sjaroslo
08-01-2012, 11:59 AM
I thought a Chevelle was a full-frame car?? What do I know... :-(
carguy502
08-01-2012, 12:22 PM
Chevelles are full frame cars like all GM a-bodies, but DSE cut the frame up firewall forward. I do not know why, but whatever those guys cut apart, I can assure they can weld is back together!
Don
MuscleRodz
08-01-2012, 03:18 PM
you could always graft in an X-gen clip which will have similar geometry.
chevelletiger
08-02-2012, 07:46 AM
I called them they said the cut the frame off because it was easy for them to work on thats all.for 140 bucks i think instead of the trz buckets i could just get tube from work and make the plate up top on the lathe...lets see!
chevelletiger
08-02-2012, 07:54 AM
