View Full Version : Vortec headed 355
Jameson
07-24-2012, 06:46 PM
Short block has about 3hrs of run time on it, pulled it from my car and picked up the vortec heads and started running with it until I got to the point that it will not be pump gas friendly. So time to change directions and cut my loses, I have close to 6000$ into this motor and most of the reciepts. Bottom end was built buy my machine shop. Currently the motor does not have the passenger side head installed so that I can show how clean it is and that it has not been run with the new heads installed. Will be assembled when purchased so that I can give the piece of mind.
2000$ FIRM!
- 1970 350 300hp 2bolt Block 010 and 020 block that had been hot tanked, decked, bored .030 over threads chased, oiling ports opened up and crank bearings .010 over.
- Bottom end consists of casting # 442 steel crank, Keith Black forged Aluminum Flat tops with 2 valve reliefs, 4340 Forged I beam rods bushed, ARP main bolts, and ARP rod bolts, and cleveite 777 bearings and fully balanced as well.
- Heads are 906 Vortecs that have been hot tanked cleaned, pressure checked, fluxed, decked, valves cut to 2.02 and 1.6 stainless steel 1 piece valves, ARP screw in studs, ARP guide plates, and Proform 1.5 roller rockers, ARP head bolts and measure in at 60cc and have been cut to accomidate .650 lift cam.
-Valve train is Howards cams circle track .485/.502 cam, Howards anti pump lifters, Crane Cam 135lb seat dual springs, Cloves double roller timing chain, and Comp Cams .080 pushrods.
-Melling High volume oil pump and 7qt claimer pan with baffles, Engine has 45psi at idle and 70psi at 3500 RPM’s.
-Pertronix flamethrower Distributor, Taylor 8.8 wires, Moroso aluminum water pump.
-Schoenfeld headers 1-5/8 to 1-3/4 primaries with 3in collectors.
-Mechanical fuel pump
-1.5hp mini gear drive starter
-Pro Comp vortec high rise 3000-7500rpm operating range.
Static compression is 10:8.1
https://static1.pt-content.com/images/pt/2012/07/IMAG0677-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMAG0678-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMAG0679-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMAG0680-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMAG0681-1.jpg
https://static1.pt-content.com/images/pt/2012/07/IMAG0682-1.jpg
shmoov69
07-24-2012, 08:32 PM
Sounds like a good build.
As an FYI to potential buyers, I had a 355 that was VERY similar except it had the 11:1 slugs and I drove it all the time on 91 and had ZERO issues with detonation. I guess the head design helps with that? Just wanted to help plug it by saying that it will prolly be fine on the street.
Jameson
07-24-2012, 09:41 PM
I appreciate the post, I have been bitten by the LS bug and want to go LS1/T56 in my SS im building so this thing needs to go.
Jameson
07-28-2012, 06:00 AM
Up to the top...
woody80z28
07-30-2012, 06:45 AM
11:1 on 91 is impressive! My Vortec 355 is 10.55:1 and I run it on 93 with no issues - it would probably be fine 91 too, but we don't have 91 in NY. Good build! And it should be very streetable.
Jameson
08-02-2012, 06:22 AM
Back to the top!
Jameson
08-08-2012, 04:44 PM
No interest?
Jameson
11-02-2012, 06:31 PM
Price drop! ready to get this moving!
Jameson
11-04-2012, 04:02 PM
ttt
Jameson
11-09-2012, 08:42 AM
ttt price is OBO... Need this gone!
SicMonte
11-10-2012, 03:31 PM
3 hours of run time? drag strip?
I'm interested but not at $3500....all I need is the motor and not all the other stuff.
Jameson
11-11-2012, 06:58 PM
No, It was built for my circle track car but never raced. I broke it in after building (1.5 hr) Drove it around to test clutch linkage and play with brakes around my house (1hr) Track roll in (.5hr) Then puked out a driveshaft and the car was parted... PM sent Doug
Jameson
11-21-2012, 04:48 PM
Ttt
Jameson
12-02-2012, 06:18 PM
Price drop to bottom dollar!
Jameson
12-14-2012, 09:27 PM
Come on need this gone!
Jameson
12-29-2012, 04:32 PM
Back up to the top!!!!
TheJDMan
12-30-2012, 07:30 PM
PM sent.
Jameson
01-01-2013, 05:50 AM
Pm replied!
Jameson
01-01-2013, 03:32 PM
Up to the top, still forsale...
