View Full Version : need some help from the suspension gurus!!
bel_mor
06-30-2012, 03:33 PM
so I need some suspension education. I got a 86 monte ss it pretty much is bone stock appearing 61411 61412
i dont want really low maybe an inch at the most. but more than any thing i want to stiffen it up a little so it will handle better.
I converted it to a big block and am having a hard time finding off the shelf springs.. How do I deter-man the right setup for my front end?? will i have to do somthing like install spring helpers so my exhaust dosent drag the ground? and just deal with it? dont have alot of money to spend on it so any suggestions would work
Bryce
06-30-2012, 05:25 PM
ridetech has a great spring rate calculator that will also work for non coilover springs.
You need to know the amount of travel you want and the corner weight. As well as spring length at ride height.
exwestracer
07-02-2012, 02:52 PM
As Bryce mentioned, the real key is the front end weight and installed length of the spring. You have several rates and free lengths available from the circle track world.
Find a friend with a set of scales.
csouth
07-02-2012, 03:50 PM
Once you get the info mentioned by Bryce and Ray, Eaton Detroit Springs should be able to help you if you cant find what you need. They can make springs with custom lengths and rates. www.eatonsprings.com
Bryce
07-02-2012, 04:46 PM
I have scales if you find yourself in san diego.
UMI Tech
07-02-2012, 04:51 PM
We have been having good luck with QA1's Pro Coil system. The adjustability allows you to miss the spring rate by a few pounds with no penalty.
We can do these handling kits with QA1's up front instead of the standard Eibach kits.
http://www.umiperformance.com/catalog/index.php?main_page=index&cPath=8_265
http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_57_150&products_id=567
And Ray and Bryce of course know the key to hitting a standard spring perfectly. Just don't take that super nice car to an oval track shop to get it weighed or it might get highjacked. That thing is sweet.
ramey
marolf101x
07-03-2012, 05:02 PM
Or you can just bring it to a Good Guys show on "Super Sunday" (when they let in the "newer" cars) and we'll weigh it for you and tell you the spring rate you should run.
We hope you consider our parts for your project, but in the end this is all about helping out fellow car guys@
