    Results 1 to 17 of 17
      NYC
      biggest wheel to fit in the front of a 66-67 GM A-Body?
      Whats the biggest tire size you can fit in the front of a 66-67 GM A-Body?i seen some 275s in the front of some camaros and thought it looked awesome!
      George
      `67 Buick GS 400 Hdtp,494ci Stage 2 BBB,5-speed TKO-600,"The Black Widow"
      Dallas TX
      My old Cutlass I ran 255-40-18 on a 9" front and 285-40-18 rear on a 10"
      Apr 2011
      mass
      i am sure with the right backspacing and lower contol arms you could fit a big tire up front. i only run a 245/40/18 but i run a kore3 hubs and c5 rotors and caliper so for me i would need a wheel with less back spacing but i got tons of room with my ridetech lower control arms and hotchkis upper arms.
      love your buick also.. thier isnt many of us out thier
      NYC
      im not so sure the inner fender wells are wide enough to put such a big tire up front,the 255 may be the biggest,i also have a 245 up front and a 295 in the back
      George
      Loganville, GA
      I ran a 275/40/17 V710 on my 67 El Camino on 17x9 wheels with 5" backspace. I did have to clearance the inner fender where it meets the fender and remove the center bolt there are well. They fit but weren't ideal. On the street I had 245/45/17s on 17x8 wheels, they fit quite well. The Elky was lowered quite a bit which didn't help.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      NYC
      Yea fender wells arent too big on these cars,maybe ill stick to whats in there or try a 9" wheel with 255 like the olds
      George
      May 2000
      I ran a 245 on a 19x8, and I think that was about max. Depends on how low it sits.
      ROBBIEVILLE
      Country Flag: Great Britain
      Mark M66 I am in the process of ordering some expensive wheels and want the 19 set up in front looking at 245 40 19 is that what you ran and how much drop did you do ? rob
      1966 GTO HELL BEAST PROJECT
      Feb 2011
      Mid-Michigan
      Cole Quinell runs a 265 on his 66 Chevelle. I believe it is on a 9.5" rim, 18" diameter.
      I'm pretty sure Tom Farrington runs a 275 on the front of his.
      Aaron
      65 Chevelle, LS1 with a T56
      Project G-Velle
      May 2007
      Mooresville, Indiana
      We're running a 275/35-18 BFG Sport Comp-2 on our 66 Chevelle with DSE suspension (splined anti-roll bar) and have 18X9.5" wheels with 6" of back spacing. They barely rub a few spots and that is only under extreme use... A 9" would be best, but Vintage Wheel Works doesn't offer one so we can live with a little shiny metal.
      NYC
      Nice,and what are you runnin out back?
      Quote Originally Posted by tommycomfort View Post
      George
      May 2007
      Quote Originally Posted by staged67gspwr View Post
      In the rear we have a 295/35-18" BFG KDW on a 18X9.5" with 6" of back spacing. Normally it would be a 5.5" back space, but we're using a 68-72 rearend which is 1/2" wider on each side. The 295 is a snug fit also, but again only rubs ever so slightly under extreme use.
      NYC
      Yea thats what i have out back also,i wanna put wider up front.
      George
      Sep 2010
      corona,ca.
      tom,when you say the rear tire rubs,is it on the frame rail or inside quarter panel lip?thanks.phil
      72 chevelle.
      May 2007
      Quote Originally Posted by chevelletiger View Post
      Phil,
      Our 66 is probably different than your 72, but we have slight rubbing on the strengthening bulge that is above the wheel lip and also on the inside rear of the wheel well. The frame is still a long way away in that area so that hasn't been an issue. All that will change soon since we are working on the ABC Performance mini-tub kit and will be able to run a 335 (if we desire).
      Jan 2013
      New York
      That is a NICE 66 Cutlass....
      ROBBIEVILLE
      RIMS & WHEELS On a 66 GTO
      Currently running 245/40/18 front 18X8 and 265/35/20 on the back 20x10, had to dice the inner fender a tad on the back, will be switching rims soon to 19x8 /20x10 soon
