    Results 1 to 7 of 7
      Nov 2010
      orlando fl
      Why would sound just turn off and back on?
      I have a kicker 4 channel amp pushing a set of kicker 6x9's in the back and a set of 3x5's in the front..with a retro sound head unit that I only run an aux wire out of to play my iPod. The sound today for the first time just started cutting in and out. Should I be looking for a lose wire? Or is there something going on with the amp? Should I check the wires and fuse under the hood? I also have been dealing with something majorly drawing my battery...could this be related? Just thought I'd get some ideas.... I know you can't know exactly tell me what it is... Just thought I'd get some good ideas...hopefully it could something simple....thanks for the feedback
      Sep 2011
      Eagle Point, Oregon
      I've had similiar problems that resulted from bad RCA cables and also from the aux wire the plugs into your ipod, as they get ware and tear from being moved and flexed...could be an easy fix,as for the battery drain might check that the signal wire to the amp is actually turning it off ? Just an idea, good luck
      Little know fact: Cocaine is the 2nd most addicting white powder in the world, second only to fresh snow
      Aug 2003
      Byhalia, MS
      Has your car been cranking properly lately? I would check the battery voltage first. Your alternator may not be charging correctly or your battery may be going bad. If those check out, then I would start checking the stereo install and make sure you have no loose wires and that all wires are completely functional
      May 2012
      Elizabeth City NC
      Quote Originally Posted by makoshark View Post
      Is the amp going into thermal protect mode?
      2005 Joe Gibbs Silverado #396
      1988 Monte Carlo SS 5.3/T56 and a whole bunch of mods.
      1970 Monte Carlo - The new project
      Feb 2009
      Laramie, WY
      I had an amp shut down, because it had to small a power wire. It wasn't getting enough power.
      Tim
      1971 Buick Sportwagon pro-touring project. Buick 455 TH350, SPC front suspension, UMI rear suspension, KYB shocks, Slowly getting there.
      1985 Ford Crown Victoria 2 door next project.
      Sep 2010
      Benicia, Ca.
      Check you remote turn on wire, that can easily be the problem.
      The ipod cables are pretty crappy for the most part so check into that too but if its the cable it will usually cause the Ipod to pause...if it keeps playing but just no sound i would start looking at your wiring...
      Matt
      MCB - Matt's Classic Bowties
      5360 Gateway Plaza Dr.
      Benicia, Ca. 94510
      866-628-8746
      TEXT ONLY: 925-989-9091 (Replied 8-4)
      www.mcbparts.com
      Email: [email protected]
      Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
      Hours: Monday to Friday 8am - 4pm Pacific
      We ALWAYS enjoy talking to our customers!
      We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
      Apr 2012
      Virginia Beach, VA
      I agree with Matt, number one problem of amps shutting down and powering back up, is because of power loss at the remote power wire, they can cause many headaches just had it happen and took about 2 weeks to figure it out.
