    Results 1 to 20 of 33
      Aug 2011
      Bay Area CA.
      BMW rims for 69 camaro
      Hey guys I have been reading up on BMW rims and was wondering what u think about these wheels. I know i will need adapters and hubcentric rings. Let me know if you have any photos of the rims on any camaros. Also any other details that i need to know to get these wheels to work. thanks. heres the CL link. They are off of an 03 5 series. What size spacers should I get? I have used the search option but its a bit confusing to me.
      http://sfbay.craigslist.org/eby/pts/3077593483.html
      May 2009
      Connecticut
      Those are alright but imo M-parallel's on a 69 camaro look way better
      Aldin
      1969 Camaro (Weapon of Choice) in the works
      May 2006
      Rhode Island
      I can't help with any info, but those are nice lookin rims.
      Rene P.
      Oct 2010
      Santa Ana, CA
      Wheels are okay but if you keep looking for a while i bet u can find real nice 2pc or 3pc BMW wheels with tires for around that price, I have BMW 2002 M5 wheels on my camaro and i didnt need any spacers up (20x8.5") front and in the rear (20x10.5) im running 1.25" spacers. It is incredibaly easy to fit BMW wheels on older chevys and realy cheap too!
      Havii Gonzalez, OC Calif.
      68' MARO - UNDER FULL RESTO - LSX ect..
      Used to be known as stilo
      Jun 2012
      m5 wheels work without adapters, m3 wheels need 1" adapters. I have bmw wheels on my firebird.
      m5 wheels have +10mm offset, and m3 wheels have +32mm offset and are no good.
      but on ebay try looking for a set of m5 wheels for 379 or best offer in 18" staggered....
      offer him 300 and for 450 it'll be to your door.....
      Aug 2011
      Bay Area CA.
      Thanks for the advise. I read all the threads relating to BMW wheels and everyone has different opinions on running them. I plan to auto x but for now they are just to look good on a budget. I looked at the M parallels and like the look but was looking for something a bit different. lucky13 i will look up the ebay auction on those wheels and see how i like them. what size tires are u running?
      Sep 2004
      You should at this thread https://www.pro-touring.com/showthre...eplacement-set! if you're thinking of running BMW wheels on a chevy bolt pattern car. See post #4.
      Brian P
      Jun 2012
      my tires are small, 235/40r18 fronts and 245/40r18 back. going bigger on the back later, theres room for it.
      May 2006
      Rhode Island
      Quote Originally Posted by BrianP View Post
      You should at this thread if you're thinking of running BMW wheels on a chevy bolt pattern car. See post #4.
      the link to that thread isn't loading Brian.
      Rene P.
      HILLBILLY HOLLYWOOD, TENNESSEE!!!
      Just remember that wheels/tires are the MOST important upgrade in appearance and possibly performance on your car. Before you "settle" for wheels that need adapters AND have fitment issues there are lot's of BMW like appearing aftermarket wheels that may not need a "band aid" to fit your car.
      Mike
      Remember, "Drive Fast, Turn Heads, Break Hearts!"
      www.musclecardeals.com
      California
      Yup.
      5 or 7 series wheels have a more proper offset for our cars, so with hubcentric rings everything should be ok. Do NOT run them without adapters or at the very least, hubcentric rings. I honestly don't know how it happened seeing as my engine isn't all that powerful (450-500hp at the crank), the axles (and studs) were only a few months old, and I was just cruising down the freeway. Apparently that .65mm makes a massive difference.
      Matt
      Sep 2004
      milledgeville ga
      19 * 8.5 front 19 * 10 rear
      Wheels came off 5 series Bmw
      Aug 2011
      Bay Area CA.
      Gasfumes those wheels look sick on the car man. Also I will for sure be running adapters from what I am reading on the forum. The search forum is great but there is sometimes too much for me to take in. I am also reading that the aftermarket eBay wheels are bad and not to buy them so I think I will continue to read but I will most definitely be doing this the safe way since no looks are worth risking my safety.
      Mountain Springs, Texas
      Quote Originally Posted by DarkoNova View Post
      Yup.
      I think it happened because you were not using hubcentric rings. The wheels studs carry a higher load under that condition.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      SAN FRANCISCO BAY AREA
      Man, you hella faulty. Time to sell that thing and buy a Chevelle.
      Aug 2011
      Bay Area CA.
      Lol. Nah if I had a Chevelle I may end up like you and it would never leave the garage.
      Jun 2012
      just to put my 2 cents in though..... My bmw wheels have been on there for almost a year.... thats about 15k miles for me, and there have been no issues.
      Feb 2011
      Yup. It makes a huge difference. A wheel stud is designed to take the tensile load of torquing it down straight into the lug seat of the wheel. If the lug seat is now in the wrong position (BMW wheels) the lug still finds its way into the seat but by doing so it has to bend the wheel stud. This bending load significantly drops the remaining strength in the stud.
      Also the studs do not take a shearing load. The friction produced between the wheel and the rotor is what takes the shear. The studs and lugs purpose is to put enough clamping load into the joint to create enough friction to handle the load. So I really don't see how hub centric rings is going to help this situation. The stud is still taking the bending.
      John
      Feb 2011
      Quote Originally Posted by lucky13firebird View Post
      And how much do you value your Firebird? More or less than the cost to re-drill the lug seats in the correct location? Yesterday's success is no indication of tomorrow's success.
      [QUOTE=jpgolf14;915799
      John[/QUOTE]
      That is interesting. A little digging around with Google finds a lot of debate on this. I see what you are saying and it makes sense. I'm still going to keep using my hubcentric rings though. Can't hurt and it they don't cost much.
      Thanks for posting.
