View Full Version : SSBC Tri-power brake
medbali76
06-16-2012, 03:26 PM
I know most of the people swear on the Wilwood and Baer brakes but what about SSBC's Tri-Power kits? Are they good for track use?
medbali76
07-20-2012, 12:57 PM
Well, I went with SSBC.
I have just received their front (TRI Power) and rear (Sport R1) kits.
The front is a 3 piston floating caliper and the rear is a single floating caliper with 13" front and rear rotors ( which are actually around 12.8" measured by measure tape)
Will see soon how they work.
[ATTACH=CONFIG]62240
jpgolf14
07-20-2012, 01:52 PM
Looks great. Do you happen to have the piston sizes handy?
medbali76
07-20-2012, 02:24 PM
They are 3x38 in the Tri power caliper and 1x54 in the Sport R1
Toadman
07-20-2012, 04:30 PM
For what it's worth, I'm running the SSBC D52 replacement front calipers, and while I haven't had an issue with them, I called their customer service looking for something for rear discs & got cut short. Looks like some kits on their website would work, but I got brushed off. I was VERY disappointed! For that experience alone, I plan to switch to Wilwood all around in the near future. Plus, Wilwood is always very supportive of the website & our events!
robertjra
07-20-2012, 09:42 PM
im running the ssbc brakes too!!!
https://static1.pt-content.com/images/pt/2012/01/386435_334555629896271_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2012/01/396970_334557346562766_100000255100572_1-1.jpg
https://static1.pt-content.com/images/pt/2012/01/381347_334554746563026_100000255100572_1-1.jpg
medbali76
07-20-2012, 11:21 PM
That is strange, as you see I am not american but I got a very helpful costumer service from SSBC. I got answer for my questions every time.
First I wanted to buy Baer brakes but they did not answer any of my emails so and I ended up with Baer and contacted to SSBC.
medbali76
07-20-2012, 11:26 PM
Nice kit.
I got the grooved rotors maybe I will upgrade them to this crossdrilled type. They look better.
Have you installed yet?
Do you have SSBC all around?
jpgolf14
07-21-2012, 10:36 AM
Wow, that is a huge piston area. I have a database of different kits. Would you be able to weight one front and one rear caliper without pads? Also, based on your measurements it sounds like they are using a C6 rotor, do you agree?
medbali76
07-21-2012, 11:32 AM
I can weigh them tomorrow no problem. They are aluminum and pretty light. How big is the C6 rotor?
These are around 12.8" x 1.125" front and rear size are the same.
I read on the Corvette forum that a few of C5 guys are running the SSBC Tri Power on the track instead of the factory brake and they are very happy with it.
robertjra
07-21-2012, 11:45 AM
Nice kit.
yes parts are installed car is not running but I have installed 10-15 of the big bite kits good brakes!!!
medbali76
07-21-2012, 11:52 AM
Which rotor size you have?
medbali76
07-21-2012, 11:53 AM
Good to hear that :)
jpgolf14
07-21-2012, 01:27 PM
Interesting I don't have a rotor that size in my table Closest I see are C5/C6 which should be 12.8" x 1.26" or the C4 HD which is 12.99" x 1.1". Would you mind weighing the rotors as well?
medbali76
07-21-2012, 01:41 PM
Sure, I will do it tomorrow morning. It is close to midnight here in hungary now. :)
medbali76
07-22-2012, 06:11 AM
Here are the numbers. Unfortunately my digital scale broke down so I used a conventional one.
Front Tri Power caliper is 5.77kg (12.72lbs)
Rear Sport R1 is 2.550kg (5.62lbs)
It seems they are not the lightest calipers on the market at all :)
Here is a pic of these calipers side by side.
62265
jpgolf14
07-22-2012, 08:20 AM
Wow those calipers are huge. They really look great. Never seen a sliding caliper that large.
I ran the numbers and these are very powerful calipers combined with a large rotor make for a very efficient system. For reference, the chart compares performance to the top line, which are the stock brakes on a third gen Camaro.
https://static1.pt-content.com/images/pt/2012/07/7622751418_efe0badbc4_h-1.jpg
medbali76
07-22-2012, 09:46 AM
Yes, the Tri powers are huge pieces. Maybe the pic is cheating a little on the real size compare to the smaller caliper but it is really impressive by visual.
According to your chart it seems these SSBC kits are really on the top line.
It would be very interest to see some Baer and 6 piston Wilwood kits in your comparison chart.
I wanted to buy the Baer's T4... I am wondering if it is better or not.
jpgolf14
07-22-2012, 11:02 AM
Yeah I am surprised to see the SSBC kit with that much piston area and the huge rear rotor. Pay a lot of attention to those last two columns. And figure out what you prefer. Personally I like a short moderate pressure pedal. So for me a moderate piston area on a big rotor is good. I do not like how long the brake pedal is on GM cars normally. As with everything on cars, its a compromise. Bigger is not always better.
I would love to add teh Baer kits but I can't find the piston sizes online. I do not like that Baer keeps them secret. If you have the info, let me know.
The Wilwood 6 piston kits typically have about the equivalent piston size to their 4 piston brothers, but it would still be interesting to see them there.
Also, for my chart keep in mind I am making the following assumptions:
Same caliper flex in each kit
Same pad compound
Same master cylinder bore size, pedal ratio, vacuum booster, ect..
medbali76
07-22-2012, 12:03 PM
Same pad compound
Unfortunately I don't have any info from Baer calipers.
I will have manual brake and SSBC sent me a MC with 1" bore size. Will see how it works.
