Results 1 to 10 of 10
06-14-2012 #1
- Join Date
- Aug 2011
- Location
- Bay Area CA.
- Posts
- 136
Starter for 383 seems to be hitting fly wheel
Ok so I removed the stock starter and am replacing it with a Powermaster mini starter part #9000. The issue is that the starter looks like it is hitting the flywheel. I used the shims that came with it and am still having an issue. I also used it without shims and won't work either. I pulled the starter and tested it and it works fine. I turned aligned the teeth with the flywheel and it worked. I guess my main question is how many shims have you all had to use. Only 2 shims come with the unit. Would I new to buy more shims to install between the block? Would there possibly be a different issue. I believe this starter works for my flywheel . Please let me know if you have any answers. I am not the most savvy but I don't think it could be that hard. Thanks in advance and I will at least post pics of the car so the thread isn't too boring.
