    Results 1 to 5 of 5
      A/C question LS2 69 camaro
      Guy's got a trailblazer ls2 in my 69 camaro and i'm using the trailblazer accesories same as truck i think,long story short ready to install the a/c system and will be using vintage air,my question is can i use my accesories or should i look and changing them,i know that quick offers so nice brackets for the a/c and alternator and also my subframe has been notched for the compressor when it had a lt1 in it but probably would rather mount it up high,any suggestions?THANKS!
      bowling green,ky
      You'll have to use quick bracket w your truck accessories.
      Pensacola, FL
      Vintage Air does have a low mount bracket for LS motors, but not sure if its set up for truck acc or F body. Depending on how much the frame is notched it may or not fit anyway. I've used the quik bracket several times & it seems to work well.
      bowling green,ky
      It's for a vette. I am running vette accy system don't know if it'll work on f-body
      Jun 2009
      Piqua, Oh
      I bought the LSx AC mounts from VA. Unless you are movng your engine way forward, their brackets won't work on a First gen. I should have returned them... But didn't really discover this for like 2 years after I got them.
      Mike South
      1968 Camaro SS/RS LS1/T56
      Ride Tech Tru Turn, Ride Tech T/Q Coil-overs
      Ride Tech 4-link
