jwcarguy
05-12-2012, 08:30 AM
- I have a complete LS1 / t56 dropout from a 2000 WS6 Trans Am (F-Body Camaro SS Z28) that was adult owned and maintained
*only the engine is available* (trans is not)
the engine is stock with no aftermarket modifications ran excellent prior to removal
The complete LS1 engine assembly includes:
factory LS1/ M6 engine harness and pcm (#09354896, harness needs a few wires repaired)
all front engine accessories (f-body) alternator, p/s pump, a/c compressor, water pump, tensioner & idler pullies
stock LS1 intake assembly with dbc (drive by cable ) throttle body
stock F-body exhaust manifolds w/ egr tubes (have y-pipe available)
starter
all ignition coil packs & harnesses
all engine sensors
will include flexplate for auto transmission (4L60E)
also have F-body (Camaro / Firebird) positive / negative battery cable harness
SOLD!!!
- Factory LS6 Intake assembly complete
part# 12573572
complete with fuel rails, injectors, map sensor, seals and throttle cable bracket
This intake is a great upgrade for a LS1 or Vortec series truck engines (ie 4.8l , 5.3L , 6.0L LQ4 , LQ9 , etc)
ready to bolt on
asking $500
- Brand new in box Texas Speed / Comp Cams Tsunami camshaft
for gen3 LS / Vortec series engines
This cam is brand new, just out of box for pics
retail for $389 + shipping
specs.
valve lift (int/exh) 647/608
dur. @.050 (int/exh) 235/240
LSA 111.0
asking $350 obo
- pair of low mileage (28k) cylinder heads and Intake manifold setup off a 2000 C5 Corvette LS1 engine
Cylinder Head Casting # 853 cathedral port the heads are complete with rockers , stands, valves, springs, etc.
SOLD!!
- complete set ( for two heads) of low mileage (40k) rockers and stands from a 6.0L (will work on 4.8L, 5.3, 6.0 LS1, LS6)
$60 for both
- one set of 8 brand new GM L92 intake valves 2.165" part #12590771
$30 for set of 8
- stock LS1 "spider" coolant crossover tubes (4 port) used in good shape (2 available) SOLD!!
SOLD!!!
- complete 2002 LQ4, LQ9 6.0L / 5.3L truck intake setup, with (65k miles) complete with fuel rails, fuel injectors
asking $75 obo
most parts will fit various LS1, LS2, LS3 , LS6 , 5.3, 6.0 L92 engines used in street , pro-touring , offroad sand rail and drifter , drift cars
In Las Vegas
call (702) 677-4085
starter
all engine sensors
SOLD!!!
part# 12573572
ready to bolt on
asking $500
specs.
LSA 111.0
asking $350 obo
SOLD!!
$60 for both
$30 for set of 8
SOLD!!!
asking $75 obo
In Las Vegas
call (702) 677-4085
