    Results 1 to 11 of 11
      Jan 2003
      Arizona
      Universal Paddle Shifter: Ford, Mopar, etc.
      ANNOUNCEMENT: In addition to our direct fit 67-94 GM paddle shifter, we now offer a universal desing that works in conjunction with 3-bolt steering wheel adapters from Grant Products.
      For many decades, Grant Products has offered steering wheel adapters that are splined in the center and accept three 1/4-28 bolts in a triangular pattern around that center. These adapters are available for a wide range of applications. So if you have a 67 Mustang, 69 Charger, or a 55 Jeep or even a pre-67 GM car like a 65 Malibu or 57 Chevy, we can now adapt a paddle shifter for your application. Of course, you still need an electronic trans, manumatic ready trans controller, and aftermarket steering wheel 5-bolt, 6 bolt, or 9 bolt steering wheel.
      The universal Paddle Shifter design and initial production run are complete. We are now accepting pre-orders. However, orders will be held until field testing is complete--about two weeks. This important step in the process is designed for your safety. Please be patient. If you'd like to get on the waiting list, you will not be charged until date of shipment.
      Check out the pix below (which also show-off our new, shorter paddle design.
      /Steevo
      ________________
      Steve Chryssos
      Nov 2001
      Sacramento Ca
      Love the new paddle design.
      Tony Langlois
      1966 Corvair Monza
      Jan 2000
      Thousand Oaks California
      Eventhough I have a six speed I think I need one for something. Maybe a line lock? or????? Something. It's just too cool not to have.
      Larry Callahan
      SouthTX
      Quote Originally Posted by streetfytr68
      /Steevo
      Is the Shrifter available for a Ford AODE? I am planning on installing an OD trans on the 65 Stang.
      Jan 2003
      Arizona
      Yes. The AOD-E will work.
      /Steevo
      ________________
      Steve Chryssos
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by Larry Callahan
      Turn signals? :D
      1968 Track Rat Camaro:
      Jan 2003
      Arizona
      That would be the world's most expensive turn signal lever. I wouldn't waste my time or money on something as simple as a horn, but the Shrifter CAN be configured to trigger any two momentary or latching electrical switches--not just transmission controllers. Some more appropriate applications would be nitrous arming/activation, gear splitter, air ride or hydraulic suspension, line loc, etc. Relay's are built into the electronics for both channels.
      We did sell one to a guy with a rock crawler, but don't ask me what he did with it.
      /Steevo
      ________________
      Steve Chryssos
      SouthTX
      Hmmm, my 65 Stang will soon get the AOD-E and already has a 250 shot of nitrous...very interesting. Looks like I now need the Shrifter for sure!
      Jan 2003
      Arizona
      Awesome!! You'll have a blast while tweaking the WOT map to best "manage" the hit from the laughing gas.
      ________________
      Steve Chryssos
      Laramie, WY
      I got your email today Steve. Now I just need to get the tranny and the controller and I am all set. Towncar with paddle shifter way cool.
      Tim
      89 Lincoln Towncar pro touring project ( new info found for handling)
      95 Explorer XLT OFF-Roader
      95 Chevy Suburban LT 4X4
      07 Harley XL1200L Low 08 Harley XL1200N nightster
      Would you vote for someone who doesn't stand up for the flag?
      Jan 2003
      Arizona
      Cool. In your case, maybe you should look into scavenging the "mod" engine, trans, ECU, and floor shifter (and maybe seats) from a wrecked Lincoln LS. Then you would only have to splice into the floor shifter's manumatic wiring. It's the long way around, but definietly a cool "pro-touring" plan. You might run into trouble with the ECU looking for ABS and other unrelated sensors.
      /Steevo
      ________________
      Steve Chryssos
