    Results 1 to 4 of 4
      Feb 2011
      central WI
      reflectix for insulation, noise reduction...under carpet and behind panels
      anyone ever use this stuff called reflectix, if so tell me what you think...
      i want to use something to quite the noise and that is not sticky or a painted product.
      Dec 2010
      St Louis
      Reflexit made the footwells of my 68 corvette tolerable from engine heat but does nothing about sound.
      On my last car, I used fatmat for noise, followed by reflexit for heat, then the factory tar paper and jute back insulation. Very quiet and comfy.
      Indianapolis, Indiana
      I have used it before. Works decent. It is fairly inexpensive to purchase. Don't know how well it deals with moisture if that is a concern to you or not. I used it on an Oldsmobile I had. Helped with heat. Not much in the way of sound dedening. I used it over the factory sound deadener.
      Ben Mowery
      67 Firebird -Powered by Pontiac w/ RAM AIR V.
      Jun 2009
      Central FL
      Is that the bubblewrap like stuff? If so, I used it behind my headliner for heat. It's worthless for sound, so I did some aluminum backed sound deadener behind it.
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
