View Full Version : Ls1 build question
Flush 71
05-08-2012, 06:19 AM
What is the biggest bore and stroke you can do to the motor to get more power but still be reliable as a weekend street car? Hope i worded that right! lol
Chevelle598bb
05-08-2012, 08:30 AM
What block are you going to use? A factory ls1 block, lq4, lsx, ls3?
Flush 71
05-08-2012, 06:56 PM
factory ls1 block from an 02 corvette
lickitysplit
05-09-2012, 04:37 AM
383 is the biggest the ls1 will go before needing to sleeve the block, factory it is 346. At that time, its better to just get a 6.0.
Chevelle598bb
05-09-2012, 04:44 AM
Yep 383 is all you can do. A 4.0 stroke crank will make 383 with an ls1 block. Make sure you use very good components and excellent machine work. The 4 inch stroke crank will pull the piston partially out of the bore at bdc and does tend to wear the pistons a bit. Just use good machine work and keep the piston speed down and you will be good to go.
If you step up to a 6.0 block then you can do all the way up to a 416 depending on overbore.
93Polo
05-09-2012, 07:04 AM
LS1s have been built with 4.1" and 4.125" strokes but the expense and smaller bore make it a less common combination. If you're going to spend that kind of money on the shortblock most start with a bigger bore to allow the motor to breath.
6.0s have been taken out to 427s.
LS1 block bore: .005-.007 over is what most do. .010 is the generally accepted max bore on the 99+ 5.7 blocks. Again some have gone .012 even on a '98 block.
93Polo
05-09-2012, 07:06 AM
That could be an LS1 or LS6 block but the max bore or stroke doesn't change.
lickitysplit
05-09-2012, 07:09 AM
It would be extremely unlikely to have an LS6 block in an '02 Vette unless he knows whether or not it is a z06. It will be an LS1 block with an LS6 intake.
93Polo
05-09-2012, 08:05 AM
Majority did have the LS1 block and it should have the LS6 intake. The percentage of LS6 blocks depends on who you listen to. I've read 25% of '02 f-bodies had LS6 blocks, again I'm not sure I would believe this. A Z06 motor would have the 243 heads.
http://forums.corvetteforum.com/c5-tech/1798350-ls6-block-in-all-c5s-started-in-what-year.html
lickitysplit
05-09-2012, 12:47 PM
Right, never said it wasn't possible, but unlikely. And yes the LS6 had 243 casting heads. 97-98 LS1 had 806, 99-00 had 853, 01+ had 241.
Flush 71
05-09-2012, 07:52 PM
Yep 383 is all you can do. A 4.0 stroke crank will make 383 with an ls1 block. Make sure you use very good components and excellent machine work. The 4 inch stroke crank will pull the piston partially out of the bore at bdc and does tend to wear the pistons a bit. Just use good machine work and keep the piston speed down and you will begood to go.
So what are good component brands? and what kind of power numbers would that be with 4.0 stroke crank and it bored .010 over?
lickitysplit
05-10-2012, 09:02 AM
Which components are you asking about?
Flush 71
05-10-2012, 12:45 PM
The whole rotating assembly!
93Polo
05-11-2012, 07:28 AM
What are your goals? Any power adders?
90% street motor or any track 1/4 mile or HPDE time?
What parts do you have just the bare block, short block, long block?
Flush 71
05-12-2012, 09:41 AM
I would like to get about 5 or 600 before the power adder, not sure what the power adder will be yet! Not really a drag strip kind of guy more of a street and maybe some track bc im planning on going all out with he suspension, and i have an ls1 with 42k miles from an 02 vette its the whole thing minus front accessories and harness!
Flush 71
05-19-2012, 06:35 PM
Couls really use some help!
srh3trinity
05-19-2012, 08:10 PM
Spend some time on ls1tech. You can probably find somebody who has done just about anything possible with ls1 stroker combos. The other option is to call a reputable ls1 builder. There are several out there with good reputations. Try to pick one who sponsors the board here.
Flush 71
05-20-2012, 11:13 AM
Alright, thanks man!
