View Full Version : Wrapping headers
yellow1098Greg
04-23-2012, 09:28 PM
What do you guys think about wrapping headers? Just like to hear thoughts.....my floor boards are burning from those headers
Randy67
04-24-2012, 06:06 AM
Coating the headers would be better, but wrap does help some. My headers are wrapped on the Camaro but they still give off a good amount of heat. Heat shielding on the floors may be a better solution, like a reflective heat barrier on the underside and more insulation on the floors inside.
sccacuda
04-24-2012, 06:07 AM
Stainless or mild steel? The wrap does hold moisture and retains heat in the tubing accelerating deterioration. Mild steel with start scaling within weeks. Might get a year out of the headers. Stainless is a better alternative to wrap, but the quality of stainless matters.
I have a turbo car with everything wrapped, but I have 321 stainless for tubing.
astroracer
04-24-2012, 04:05 PM
Spend the money on JetHot and a good heat barrier. Like Craig said the wrap will ruin a mild steel header very quickly. I had the steel headers on my truck JetHot coated in '01 and they still look like new.
sam 74
04-24-2012, 08:20 PM
better off with a coating, i used Jet Hot, a friend of mine wrapped his headers and they were rusty looking within the first month, i'd only use wrap as a last resort. you may even want to look into DEI insulation for the floor itself before wrapping the headers.
yellow1098Greg
04-24-2012, 10:36 PM
Thanks guys...I definitely think insulation is the way to go.....so you suggest on both sides of the floor boards?
nicks67camaro
04-25-2012, 04:38 AM
I wrapped my headers since i bought them used and they had some surface rust on the jet hot coating. After 10 years i just re-wrapped one this year and there was no rust other than the surface rust that was already there.
Randy67
04-25-2012, 05:40 AM
I would put a reflective barrier on the underside and insulation on the inside, to keep the insulation from getting wet and possibly causing rust issues.
sam 74
04-25-2012, 04:39 PM
http://www.summitracing.com/search/?keyword=the-13575&dds=1
http://www.summitracing.com/search/?keyword=the-14100&dds=1
check these out they're probably what you want to look into.
yellow1098Greg
04-25-2012, 11:19 PM
Are those for under the car or under the carpet?
nicks67camaro
04-26-2012, 04:35 AM
http://www.secondskinaudio.com/index.php/products
they have very nice product and are affordable.
I used a combination of the automotive vibration mat and the thermal insulation mat.
sam 74
04-26-2012, 02:35 PM
the adhesive back can go on any surface provided you clean it well, the thicker mat is for inside use.
nathanr15
05-01-2012, 04:48 PM
second skin audio also make a sprayable heat barrier
