View Full Version : C6 power seats wiring diagram?
diesel25lrs
04-04-2012, 07:18 AM
Anyone out there have a wiring diagram for C6 power/heated seats?
parsonsj
04-04-2012, 07:42 AM
Josh,
C6 seats are extraordinarily complex. See this post on our blog:
http://blog.iimuchfabrication.com/?p=85
They have a seat controller, plus wiring for the side impact airbag, seat heater, etc. All connected to the BCM for integration to other systems. If you want more information, the best idea is to purchase the official GM books. I can help you with that if you wish.
evostilo
04-04-2012, 12:51 PM
I found it once ill try looking for it, but the power is simple just black and red/white wires, see the link below hope it helps, What kind of car you putting these in? I got em on my 68 camaro (project) still thinking of choping a few inches of the headrest tho there kinda higher then i thought they would be.
http://www.kawal.net/power%20seats.htm
diesel25lrs
04-05-2012, 11:35 AM
Thanks guys,
Going in my 69 camaro. Have them mounted & the fit couldnt be better!!! Love them! Just want to hook up the pwr & heaters- no airbags... Were u able to get them workin good stilo?
evostilo
04-05-2012, 03:34 PM
I only tested the power tracks not the heat, i already have them sitting in my car but im still a long away from driving it
diesel25lrs
04-06-2012, 05:44 AM
Did you use the GM connectors or cut them off and hardwire directly?
diesel25lrs
04-11-2012, 10:34 AM
Thanks John,
I read your link above and that mainly talks about switching other seats into a vette.
I'm using the stock C6 seats into a camaro and would like to only use the power and heat- no BCM or bags. Do I need to trick the actual Seat or plug the airbag wire somehow so it doesn't fire? Will the belt pretensioners work still?
Josh
jljude
06-21-2012, 11:13 AM
Did you get it figured out?
I think I've gained enough knowledge on how to hook these up. Does your driver seat have a memory module (black box directly under the cushion held on by tabs under the spring? the wiring for memory (I am pretty sure) just needs another power supply hooked up to the memory module (red/white) that normally gets power from the body control module. Or, what I did, was gut the memory module out and all the extra wiring and wired the 6-way switch just like the passenger side (switch direct to the motor plug), but it will require larger gauge wire.
Thanks John,
Josh
diesel25lrs
06-22-2012, 06:09 AM
No, haven't done my wiring yet...That link that stilo posted above has a pretty good diagram from what I can tell. Please let me know how yours works out!
jljude
06-23-2012, 05:31 AM
The kawal site helped tremendously. Ray is a great guy and is willing to help.
I got my power seats to work great in my 68 Camaro. I yanked the memory module out and straight wired the motors. Put in v6 heater switches and those work good. To use the memory seats, you can do it in a non memory car, but you need to have the corvette body control module, but too much effort.
diesel25lrs
09-18-2012, 09:50 AM
Got them all hooked up and working properly.....very simple- red/white power, black ground and wha la!
