View Full Version : New Dual Pump Configuration
Rick@Rick's Hot Rod Shop
07-15-2005, 05:57 PM
Here are a few pictures of our new dual pump configuration. This system can use virtually any in-tank pump. The pictures listed are with AcDelco pumps for mock up, but we will be using Bosch Pumps for the final product.
ProdigyCustoms
07-15-2005, 05:59 PM
How much ass in each pump?
Steve1968LS2
07-15-2005, 09:22 PM
Rick,
I need to talk to you.. PM me.. also, I have some great shots of one of you tanks in a car at the Good Guys show..
I want to see if you can make a direct replacement for the foam lined plastic Jegs type 16ga tank that is in Penny.. the bottom has to be the same so it fits into the metal "skin" but it can be a bit taller maybe an extra gallon or so.
I would also want it to hook back up to the external fill location using Larrys new gas cap and pipe..
Sounds like something up your alley???
Thanks!
07-16-2005, 02:34 AM
Frank,
I am going to assume that you meant to ask how much gas will be supplied form each pump. That all depends on the choice of pumps… Once that is determined we can then give you an answer of what the flow rate will be. Keep in mind that both pumps will not be operating at all times and will be controlled with a Hobbs switch.
ProdigyCustoms
07-16-2005, 04:40 AM
I'll call you Monday, I need to talk to you about a tank for Prodigy and another car.
Or you can call me over the weekend if you like, my contact info is on the website.
SSMOORE
07-18-2005, 01:07 AM
Hector is there any chance those are pics of my tank?
steve Moore
07-18-2005, 05:59 AM
Steve,
You have mail.
SSMOORE
07-18-2005, 08:57 PM
sweet
