Results 1 to 18 of 18
4 wheel disc brake conversion for a 1970 mustang
I'm planning on doing a disc brake conversion this winter to my 1970 Mach 1 as I've discovered a very simple way to adapt 13" front rotors from a 1994-2004 Cobra using my drum brake spindles. I figured while I'm at it I may as well convert the rear brakes to discs as well, but I'm having trouble finding out what to use for a master cylinder. I also need to figure out what proportioning valve to use, although an adjustable one is acceptable.
I've seen mentioning of using a "corvette type" master cylinder, but no specifics as to a manufacturer, donor car, part number, etc. Can anyone recomend a specific unit and give me a lead on where I can get one?
-Jim...
1970 Mustang Mach 1, Global West tubulars, roller bearing everything, del-a-lums, 355 Windsor Tremec TKO 600, lots more on the way
A few other cool toys too
