View Full Version : BRP Hotrods Steering arms
Roberts68
03-25-2012, 07:43 AM
These beefy billet bits came on a set of ATS Spindles I bought.
They should work with anything that uses the same steering arm if you want to incorporate a rack/pinion. I am keeping my steering gear.
They are Billet Steering arms that allow the use of a 1998-2002 F-Body rack & pinion steering according to BRP.
They are supposed to shave about 6 pounds compared to iron arms.
"BRP steering arms will help you connect the late model GM power rack to your existing spindles. Each steering arm is machined out of a single piece of aluminum for maximum strength and milled down to specs."
They retailed for $200 and there are a few competitors offering similar for that price and up.
Please note that they have some contact marks on them. I thought it best to leave them as is but a guy could probably do some cosmetic filing/polishing if your inner spindle area is likely to undergo cosmetic scrutiny.:idea:
$100 plus shipping.
Thanks for looking.
Robert
Roberts68
04-05-2012, 08:17 AM
BTT.
These will fit OE spindles and can also be used to address bumpsteer using a baer-tracker style setup with a little ingenuity. Shed a little weight and get some tuning ability.
I also have them listed as part of a package deal with the spindles.
