View Full Version : audi seats
69bigblock
03-24-2012, 04:05 PM
I have a set of 2002 audi A4 seats that I might use. Does anyone have the wiring diagram so I can find out which wire is for what.. There are 4 sets off plugs coming off the seat..
absintheisfun
03-25-2012, 05:48 AM
Get a battery and some wire and start checking the circuit...it will take a bit of time, but if you can't come up with a wiring diagram it works
69bigblock
03-25-2012, 06:39 AM
Only thing I'm worried about is there is a side air bag and not sure if poking the wrong wire will set it off..
kawaden
03-28-2012, 01:05 AM
The side air bag will have its own plug yellow or orange in color with 2 wires, blue and brown if memory serves me. It's been a while though.
Also brown is always ground with Audi
And yes if you put 12volts to the air bag it will deploy
69bigblock
03-31-2012, 06:38 AM
Thanks for the info... helps alot
kawaden
04-01-2012, 02:35 AM
no worries. if you need to know anything just ask. I still have some contacts at Audi.
absintheisfun
04-01-2012, 05:14 PM
Law requires that any and all airbag connectors are yellow. Stay away from those and you should be good to go.
Ididitmyself
03-04-2014, 10:11 AM
Hey there, quick question for you. I also have a set of audi a4 seats from a 2002. What are you using for frame rails/ mounting brackets? Thanks in advance
