View Full Version : ls1 swap help needed
Anthony Paredes
03-23-2012, 06:40 PM
I have a 85 S-10 Blazer that im wanting to put an LS1 in it so my question is were can i get the parts to swap it over. If anyone knows were to get everything i would really appreciate it thanks.
dhutton
03-24-2012, 05:49 AM
Check over on ls1tech.com in the conversions and hybrids forum.
s10pro
03-26-2012, 04:55 AM
the s10 blazer is a shorter wheel base, then the reg s10 pick up so there is 1'' mounting pas welded to the frame of the blazer, so this makes motor sit higher and some of the parts might not work. hope this helps
rusty428cj
03-26-2012, 05:05 AM
Current Performance Wiring does a lot of LS1 conversions. www.currentperformance.com
acegto
04-01-2012, 04:59 AM
Check out s10forum.com. They have an entire section dedicated to LSx swapped trucks and the sticky info will more than get you on your way.
And Jared at Current performance will build you a plug and play harness to get that truck running once you get the motor in. I DD a 91 s10 w/ a 2005 5.3/700r4 combo. Any specific questions hit me up.
bigpat1802
04-12-2012, 02:53 PM
I know speedwaymotors.com has a decent amount of things for LS swaps. I ordered some nice motor mounts, fuel system, computer mount and fittings from them for my 77 El Camino 5.3 swap. I know they have harness' too.
